Author Topic: Cb 750 f2 78 cafe build  (Read 17419 times)
Re: Cb 750 f2 78 cafe build
« Reply #75 on: March 05, 2016, 07:34:34 AM »
Yozzer beautiful build and love that gas tank - what is it and where did you get it? Does it mount with stock mounts? Petcock on either side? looks like a 5-gallon tank?
That is also the best custom oil tank I have seen on a CB750.
Cant wait to see this bike out on the road - where are you in the UK?
cheers
Andy
Offline Yozzer74
    • Yozzer
« Reply #76 on: March 07, 2016, 06:24:09 AM »
The gas tank is one that I had made Andy .by someone local to me I'm in Barnsley south Yorkshire .
« Reply #77 on: March 07, 2016, 10:53:42 AM »
Looking good. What remains on your punch list?
Hopefully a fork brace
nice build!  8)
« Reply #78 on: March 07, 2016, 12:26:19 PM »
I think he'll need an installed exhaust system, too.   ???
Offline Yozzer74
    • Yozzer
« Reply #79 on: March 07, 2016, 12:40:40 PM »
And some carbs
Offline Yozzer74
    • Yozzer
« Reply #80 on: March 13, 2016, 02:02:02 PM »
Fitted my exhaust today but when it's all tightened up it touches the sump .it's from carpys .has anyone else had this problem bike is a f2 78
« Reply #81 on: March 13, 2016, 02:16:07 PM »
Can you post up a photo of your pipe on the bike?  It sounds like it might be a quality control issue, but it's best to show a photo. If so, I am sure Carpy will send you another one.
Offline Yozzer74
    • Yozzer
« Reply #82 on: March 13, 2016, 02:18:20 PM »
I will get one on tomorrow only problem is I'm in UK  :( which makes it a little difficult for returning things
« Last Edit: March 13, 2016, 02:32:18 PM by Yozzer74 »
« Reply #83 on: March 13, 2016, 02:35:45 PM »
That sucks!  I know that a few folks have had fitment issues with his pipes, but Carpy does have a good record making things right.  Plus, he's a pommy, so I'm sure he'll take care of you!
« Reply #84 on: March 13, 2016, 04:38:19 PM »
While i'm no fan of Carpy, if you fit a rear mount on that pipe, you should be able to clear the sump, ideally, you want the pipe as snug to the engine as you can get it, without touching of course... ;)
Offline Yozzer74
    • Yozzer
« Reply #85 on: March 14, 2016, 09:19:27 AM »
Retro rocket think your right if I fit a back bracket it should clear it
« Reply #86 on: March 14, 2016, 11:53:56 AM »
That's pretty close to the pan. I wonder if you can get a little bit of clearance.
Offline Yozzer74
    • Yozzer
« Reply #87 on: March 14, 2016, 11:57:14 AM »
Been in touch with carpy he said try shaving the fins down on the sump .??
« Reply #88 on: March 14, 2016, 12:00:16 PM »
Hmmm.  The fins on the sump help to cool the pooled oil before it recirculates.  Shaving the fins may help the pipe clear the sump, but given the lack of any gap to the hot pipe and smaller fins your oil may run hotter.
« Last Edit: March 14, 2016, 12:12:32 PM by CB750 Cafe Racer Fan »
Offline Yozzer74
    • Yozzer
« Reply #89 on: March 14, 2016, 12:02:33 PM »
Yeah just what I was thinking .Honda didn't put them on there for no reason..
« Reply #90 on: March 14, 2016, 12:15:54 PM »
It's too bad this is not the 2-piece pipe, where you could have the end piece bent to create additional clearance. You want to be careful how much clearance you try to create by applying force at the end of the pipe (via a bracket) with the pipe attached.  You do not want to apply force to the pipe when it is connected to the head as you can damage the head.
Do you have a decent muffler shop nearby that may be able to adjust the bends at or after the collector to give you more of a gap to the sump?
Offline Yozzer74
    • Yozzer
« Reply #91 on: March 14, 2016, 12:18:24 PM »
No not what I no of
« Reply #92 on: March 14, 2016, 01:37:19 PM »
Don't worry about the small clearance to the sump, as long as its not touching its all good... ;) I like my pipes as tight to the engine as possible, lots of bikes are set up like this, just use a bracket to take the pipe off the sump, thats all that needed, don't grind fins off the sump, stupid advice... :o
Offline Yozzer74
    • Yozzer
« Reply #93 on: March 14, 2016, 02:24:58 PM »
Yeah I pressed down on the pipe a little and it gave about 5 mm of clearence .
« Reply #94 on: March 14, 2016, 03:05:38 PM »
I would try to do the shoving and bending with the pipe NOT attached to the head.  It could cause undue stress on the aluminum exhaust ports -- just like some folks don't bother to use a bracket for the tail end of their exhaust.
Offline Yozzer74
    • Yozzer
« Reply #95 on: March 14, 2016, 03:18:32 PM »
Yep I only had to put a small amount of pressure on the end to give the clearance .
« Reply #96 on: March 14, 2016, 04:36:32 PM »
Certainly don't treat it like a gorilla and a Samsonite, but some pressure on it will be fine.
« Reply #97 on: March 15, 2016, 02:52:05 AM »
 ;D ;D
Offline Yozzer74
    • Yozzer
« Reply #98 on: May 09, 2016, 03:37:17 AM »
Got my carbs back today well happy with them
« Reply #99 on: May 09, 2016, 07:56:05 AM »
 F sumps have more finning.. trimming a fin or two should not hurt, or change to an earlier sump..
