Author Topic: DELKEVIC EXHAUST NOW AVAILABLE FOR ALL THE LATE MODEL HEADS  (Read 20998 times)
Re: DELKEVIC EXHAUST NOW AVAILABLE FOR ALL THE LATE MODEL HEADS
« Reply #75 on: September 12, 2016, 08:00:13 AM »
Did you install the pipes to the collector prior to installing to the engine? I found the springs went on easily that way using the tool they supplied.
Offline kmb69
« Reply #76 on: December 08, 2016, 12:31:49 PM »
Just spotted these: http://www.cyclexchange.net/Performance%20Pipes%20Page.htm
Nicest looking collector I think I've ever seen. Not as cheap as Delkevic's, but if you looking for POWER, these just might do the trick.
« Reply #77 on: December 08, 2016, 01:45:59 PM »
I have  a merge collector like that on a 36 year old Aussie sidewinder I have in my shop.... 8)
Offline calj737
  • I refuse...
« Reply #78 on: December 08, 2016, 02:01:20 PM »
Somehow, Aussie and Sidewinder just seem to go together in my mind  ;D
« Reply #79 on: December 08, 2016, 02:06:21 PM »
And "upside down"... :P
« Reply #80 on: December 08, 2016, 05:08:06 PM »
 Just to add a little info on the F exhaust's the 75/76 F exhaust is different than the 77/78 F 4-1.  The 77/78 is more of a tri Y in the stamped collector. The late header will fit on a K frame but the 75/76 header hits the brake pivot on a K.  I'd guess the late one is lighter by a small amount and the early collector is bigger ( 2 1/2" slips over) than the late one, maybe 2"
Offline whizzer
  • Be safe
« Reply #81 on: March 10, 2017, 12:02:25 PM »
Pleased with new Delkevic exhaust to cb350f to replace rusted 4-2.  Kit came with pipes numbered to match numbers on collector, sealing compound, stand stop, and small hooked tool to install springs from pipes to collector.   On one inside spring had to use ratchet strap and hook tool wrapped to right fork tube to stretch spring. On other inside spring used this great tool.
No drain holes.  I assume none needed since stainless?
« Last Edit: March 10, 2017, 12:04:09 PM by whizzer »
72 cb350f
66 cb77 sold
72 Suzuki gt750 given away
59 Vespa given away
06 Whizzer sold
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #82 on: March 10, 2017, 04:20:29 PM »
Those crossover pipes are super cool.
--Evan
1975 CB750K "Rhonda"
Offline Imago
  • 1978 CB750F
« Reply #83 on: March 10, 2017, 04:33:11 PM »
Yes, but I didn't put the springs on until after it was all lined up. Easy peasy. One spring was a hard pull, but not too bad.
« Reply #85 on: April 08, 2017, 07:07:58 PM »
I've had an offer from a guy who wants to swap his RC51 for my K1, but if that doesn't come off, I might buy a Delkevic pipe for it, the price is right, and it looks a lot like my old Yoshi pipe. Cheers, Terry. ;D
Offline CBGhia
« Reply #86 on: April 12, 2017, 08:30:16 AM »
Terry,
The RC51 is one of my favorite bikes.  Right up there with the FireStorm.  Those late 90s/early 2k Honda twins were awesome.
« Reply #87 on: April 12, 2017, 08:53:18 AM »
Yeah mate, I've got a Firestorm, but the RC51 was a Homologation race bike and a little bit more special again, so if this deal comes off, it'll be a keeper! ;D
« Reply #88 on: April 12, 2017, 10:30:49 AM »
You mean an American Firestorm, not a Japanese rice cooker? :)
http://saxonmotorcycles.com/firestorm/
« Reply #89 on: April 12, 2017, 07:39:22 PM »
Ha ha, no, this is my Japanese rice cooker......... ;D
Offline Skiwatcher
« Reply #90 on: October 13, 2018, 06:10:10 AM »
I just sent them a message inquiring about a 650 version.  I offered to send them a 650 header I have laying here.  I would love to have one of these pipes on my bike!
And did you have any luck? I tried to get an answer from them aswell :)
