When you remove a(old,etc.) tire w/ the tire irons it helps to put your knees/weight down to compress as much as the opposite side(180degrees)of the tire as you can at one time so you can get enough play in the bead for it to slip over the rim as you're prying it off w/ the two levers.Then just keep doing that all the way around and it works well when you're installing one also.
Tire irons arriving today, wish me luck!
After some debate I've decided to forgo the powder coat and simply spray the frame, headlight, and brackets. With the right prep and patience I believe I will be able to get a good result, maybe even close to powder quality. My initial fear was strength of the paint, but it sounds like if I let it cure for two solid weeks I should be okay. I'm hoping this will give me the hardness I'm looking for, or at least close.
My plan is as follows...
- Strip the frame. I plan on using some simple green aircraft stripper, and paint thinner. Sand.
- Primer. I've ordered two cans of Rustoleum sandable primer. This should give me a nice smooth base to spray over.
- Wetsand. 300 grit.
- Spray. I've chosen VHT Roll Bar and Chassis paint. This should give me the durability I am looking for. It is an epoxy spray paint which behaves somewhat differently from a traditional rattle can. Oddly enough I've found someone using this exact method on his CB350F. Check out his video here.
I'll apply this same process to the headlight bucket, brackets, swingarm, and any other small parts I've removed. I'm still debating what route I should go for the rims as I would like those to really stand up to the wear. I've switched over to the spray route for two reasons. 1) it's surprisingly expensive here in NYC. I've seen people on other threads saying it was $150 for a frame, prep included. Or $70 for a box of parts, it's nowhere near that here. So far I've been quoted $500-700 for the frame alone. Some people just flat out say "no". 2) the time. If I hand this off to a powder coater I'll have to wait for their schedule to get it back. I'm not in a rush, but I like to be working on my own time. I'd rather wait two weeks for my spray paint to dry than 5 days with all my parts at someones shop. Weird, but thats the way I am
Hopefully this new course of action doesn't deter too many of you. I'm confident with the right patience, prep, and paint I'll be able to get a quality finish out of this.
