Author Topic: 1973 CB350F "Modest Original" build  (Read 125361 times)
Offline iiAtlas
Re: 1973 CB350F "Modest Original" build
« Reply #550 on: February 28, 2017, 07:29:41 AM »
Vacation?   ...Larry
Was intended to be...but got sick..turns out wisdom teeth infected and have continued to give me the same recurring cold for the past few months..yikes!  Getting them yanked Monday and not looking forward to it...
Glad to hear you back Atlas.
Good to be back!  Had the power washer off and finished up the bottom half.  Couldn't for the life of me get the wiring harness portion off (I am pretty sure it is some sort of oil sender unit).  Tip-toed around it.  Whats next?
« Reply #551 on: February 28, 2017, 07:53:12 AM »
Atlas,
I would wash out the inside lower case passages completely w/ solvent before final assembly just in case any stuff from the outside of the case got shot up inside the inner oil passages when you pressure washed it.
Offline iiAtlas
« Reply #552 on: February 28, 2017, 08:34:18 AM »
Atlas,
Yes!  Above was my "before" picture.  The pressure washer has a cool feature where you can mix in soap while you spray.  Neat!  As far as reassembly I guess my next steps are all those dreaded gears...yikes!
Offline iiAtlas
« Reply #553 on: February 28, 2017, 10:29:38 AM »
I may rebuild the head today as that is sitting ready.  Anything I can should do with this clutch?  I know you all recommended sanding the disks down on some plate glass.  Anything else?  Could be a good evening project...
Offline iiAtlas
« Reply #554 on: March 02, 2017, 07:44:04 AM »
Sigh just when I think I have some time to work on my own projects!!
This CB750 Four came in in need of some help.  It is a friend of the owners of the CL350 so I said we'd take a stab at it.  She is mostly all there, or at least was for a majority of it's life.  It went in to some other shop for adjustments and came out with pods (K&N at least), megaphone exhaust, and 115 mains, much to my dissatisfaction - though I of course understand given the $$$ of a new stock exhaust!!
Anyways, she was getting 40mpg now we're at 19-20.  Would a change from 105 mains to 115's account for THAT much of a fuel economy difference?  After 10ish minutes or when she's full temp the revs start to soar, no tach but I'd guess 4,500rpm idle.  I haven't taken it out yet so I can't say much about how it's performing through the rev range.
My first thought was to look at the choke - not making that mistake again!
Luckily (or sadly?) it, and it's owner, were both operating correctly.  Throttle slides functioning as well.  Along the sides of each carb intake there are shiny marks.
I originally guessed this was someone a little to dremel happy getting in there and widening something, but after seeing similar marks on all 4 carbs I believe they are actually factory.  The owner says he's been messing with the idle etc to try to get it to play nice.  My first step will be to put it back to a base tune and see where we stand there.
When the bike first came in hot I pulled out my IR thermometer to see how it was running.  The CL350 was only running on one.  Luckily #1, #2, #3, and #4 were similar temps.  #1 20° colder and #4 about 10° colder, I attributed this to them being the outer two cylinders.  Upon closed inspection the spark plug lead on #1 was completely loose.  The little tab which applies tension to the top of the spark plug had fallen out.  Instead of being a "D" shaped hole this one was just an "O".  I am sure the others are weekend as well and not holding with sufficient force.  The #1 cylinder was most likely missing maybe 10% of the time, but I'll have to take it out for a ride to confirm that.  Anyways it seems at least new plugs are in order.  Are these resistance plugs like the manual?  And the coils, two coils on this bike?  Removable spark plug leads or no like the CL?  I will download the manual (I believe it is the the section here on the forums) and do some digging of my own.
The left exhaust is completely sooted up while the right is bone dry.  That I will have to dig in to.  I will also check to make sure we are in timing before going too deep elsewhere.
Anyways....always something!  Hopefully this one doesn't take too long and we can get back to my 350 Four.  I have decided to get a handful of my engine parts cleaned the machine shop where we have the B20 head.  I am thinking walnut shells.  So that will be good progress while I am working on this!  At least the 750 is a Four so maybe you all will enjoy  8)
« Reply #555 on: March 02, 2017, 09:52:08 AM »
Looks like a 'fun' project for you Atlas  :D I guess if it was mine the first thing I would desire(imo)would be to re-install the stock airbox an 'in box' Uni-filter,even though that won't fix the other problems.I hope your coils are evenly strong.
Offline iiAtlas
« Reply #556 on: March 02, 2017, 11:54:39 AM »
Agreed, this was my recomendation.  But that wouldn't be wise to do with the 115 main, correct?  Would want to put that back to stock which (correct me if I am wrong...) is 105.  But would still need to jet up for the exhaust, correct?  Thanks grcamna!!  Good to hear from you.
Offline iiAtlas
« Reply #557 on: March 09, 2017, 09:27:26 AM »
Now this is weird...
Idle mixture jets filled with...solder?  Compare to ones from a rebuild kit.
Who would do this?  Is this some weird "fix" to make the bike run less rich?  I have never seen anything like this - what about you gurus?  Is this some sort of "underground" mod I am not aware of?  My first instinct is to dive in and rebuild these carbs, or at least swap the idle mixture screws out with non-plugged ones...
The bike has 115 mains with megaphone exhaust and pod filters.  We have the OEM airbox with a new K&N filter.  Should we rebuild and keep pods + megaphone and keep the 115 mains? Or rebuild, swap the pods for the stock airbox + k&n filter, keep megaphone exhaust but step back down to 105 mains?
Any input greatly appreciated!  I just had my wisdom teeth pulled and have been stuck in bed until today....
