Author Topic: Fork Assembly  (Read 1034 times)
Offline rundogdave
Fork Assembly
« on: January 06, 2016, 12:44:13 PM »
I'm trying to assemble the fork tubes on a '78 b750. A book I have says to apply thread sealer to the threads and shoulder of the bolt that attaches to the piston, and torque to 35 to 40  ft/lbs. What type of thread sealer do you recommend? And does 35 to 40 ft/lbs seem to be too much for a small bolt like that? And if that is the correct torque spec, how does one keep the piston from spinning while torquing? Thanks.
Re: Fork Assembly
« Reply #1 on: January 06, 2016, 12:54:24 PM »
Offline rundogdave
Re: Fork Assembly
« Reply #2 on: January 06, 2016, 01:50:16 PM »
Good video, thanks. Picked up some useful information. I keep forgetting about youtube. But from what I've seen, no thread sealer, just the copper washer. And he listed no torque spec for that bolt.
Re: Fork Assembly
« Reply #3 on: January 06, 2016, 02:16:51 PM »
An 8mm bolt will be happy at 10-18ftlbs. Should be plenty to crush that washer.
http://www.salocal.com/sohc/tech/torquetable.htm
If the damper still turns before you get there, push the spring in and put the top nut on. Maybe after clamping them in the tree.  That should hold the damper in place to get it tight.
