I did a compression test today so I'll know before opening the engine. I'll deck cyl and head that will crank up the compression a little. Interesting to see how much more pressure it will make.
- Acceptable difference of pressure between cylinders? cold engine, last started about 3 weeks ago.
cyl 1: 180, 2:164, 3: 175, 4:175 PSI (electric starter and full throttle)
cyl 2 must have a hardware difference (problem), right? gasket leak..?
tester used was this cheap model bought locally in an auto shop selling cheap car tools, parts
http://www.cb750supply.com/images/cb750supply/parts/480/CB-70222.jpgPistons are not much used, about 6000kms. 836cc + ported head and cam numbers like an RC295
EDIT: Funny, same kind of question written while I wrote this post
http://forums.sohc4.net/index.php/topic,154269.0.htmlI'll test again after a warm up, start and let it idle 5 minutes or so.
