Author Topic: CB750 kill switch wiring.  (Read 11441 times)
« on: January 11, 2016, 10:17:13 AM »
OK I admit electrical is not my strong suit. I'm trying to wire in a "deadman's switch". A lanyard pulls a plug and kills the engine in the event of a get off.
The instructions say if you have a kill switch already (I do), then find the wire at a junction point, pull it apart and insert the leads from the DM switch. Easy peasy.
Well my manual says the kill switch (read ignition switch) has a B(lack) wire on one pole and a BW(black white) on ta other. In the Hlite shell, I trace the bundle from the right side switch. No B or BW wires. If I break the one B wire I do find, and interject the switch, I blow fuses. The only BW wire is plugged into other BW wires.
Any help is appreciated. I know its not that hard and I just have a mental block.
Is there a guide which identifies what color wire does what? I know B is power and G is ground. I think BW is power to the coils?
Re: CB750 kill switch wiring.
« Reply #1 on: January 11, 2016, 10:36:21 AM »
Why don't you track the BW wire from coils, that's where it goes from the kill switch?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: January 11, 2016, 10:59:38 AM »
Correct. The kill switch is normally closed (NC) and completes the switched hot circuit (B) to the coils (B/W).
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline edwardmorris
  • Youngish
« Reply #3 on: January 11, 2016, 11:10:52 AM »
K2 wiring diagram for ref
« Reply #4 on: January 11, 2016, 11:22:50 AM »
My bike's strapped to the trailer and the trailer is in the shop. Not much room to move around, take the tank off, etc. I'm pretty sure this can be done in the headlight shell. Maybe not?
« Last Edit: January 11, 2016, 11:28:40 AM by MCRider »
« Reply #5 on: January 11, 2016, 11:26:04 AM »
Trying not to be too impish, but I need more handholding than that.
I understand better now, thanks 70CB. But not any closer to getting the switch wired in. Where is the B/BW connection? Is it not in the shell?
« Reply #6 on: January 11, 2016, 11:28:10 AM »
Thanks EM, I do have that diagram and found the Ignition Switch (Kill switch) picture. But it does'nt give me where do I make the splice. OR maybe it does and I'm just not catching on.
« Reply #7 on: January 11, 2016, 11:29:04 AM »
No, it is in the Kill Switch.
Kill Switch gets key switched power in (Black Wire) and BW wire goes from KS to coils.
I would not mess with the right hand control, much easier to splice between KS and coils.
« Reply #8 on: January 11, 2016, 11:31:11 AM »
Ahhhh! Now the fog lifts. Sounds like the tank must come off?
« Reply #9 on: January 11, 2016, 11:34:06 AM »
Well it depends, I usually run wires inside handlebars and I would have to have really big reason to pull it out
On the other hand, power to coils is basically in the open, you could insert a wire jumper - without cutting the harness - between coils and harness and use this jumper to connect your dead man switch.
« Reply #10 on: January 11, 2016, 11:42:42 AM »
Looking at the diagram, the BW wire is only used for power to the coils. It makes an appearance in the headlight shell. There is a mail/female connector. Could I not unplug that, insert the DM switch leads, and accomplish my goal?
« Reply #11 on: January 11, 2016, 11:49:11 AM »
That would work  ;)
But I am curious how will you use this switch?  Tied to your hand?
« Reply #12 on: January 11, 2016, 12:36:41 PM »
That would work  ;)
YEs it is brand name kit, approved by various sanctions. The switch is a clamp on the bars with a socket in it. Plug the socket plug, about the size of a land line phone wall plug, into the socket on the clamp. It has mild resistance, so it will stay put.  A fixed length lanyard is affixed to one's wrist. Should the errant get off occur, the plug is pulled out and the engine dies.
The East Coast Timing Assoc requires it and we hope to go there this spring. Lucas Oil Drags doesn't require it for our class, but the next class up does, so what the heck.
« Reply #13 on: January 11, 2016, 01:39:23 PM »
Gotit.
And here I thought you want to it for your commute, hmmm  ;D
« Reply #14 on: January 11, 2016, 01:50:11 PM »
Could I offer an option: splice your new DM in lieu of the right hand control, thereby leaving the stock wiring unmolested. Yes, you can use the connection in the headlight, but easier to find the pigtail connection from the RH control, eliminate it, and plug the DM in its place. Make sense? Unless there are other functions in use from the RH control, this is the easiest and most reliable method.
I see what you're saying, but I don't want to disable anything in this process. Its still a street bike after all.   :D
If I've got this right, all I'm going to have to do is unplug the BW wire at its juncture in the Hlite, crimp a mail and female end onto the switch leads, and plug them into the BW wire. So no molestation. OCICBW
« Last Edit: January 11, 2016, 01:52:34 PM by MCRider »
« Reply #15 on: January 11, 2016, 02:39:34 PM »
Well, if you run the DM than you either supersede the KILL or you run in series to it. So that is a logic gate to think through.
I don't know, I'll let you know.  ???
Offline Mantree
« Reply #16 on: January 11, 2016, 02:54:49 PM »
Why not just snip the hot wire just before  the coil and install it there easy to get at
Sent from my ME302KL using Tapatalk
« Reply #17 on: January 11, 2016, 04:45:09 PM »
^^^ that was my very first idea.
« Reply #18 on: January 11, 2016, 05:13:46 PM »
Indulge my ignorance. Is there a common hot wire for both coils. Or if you snip one, won't the other still fire?
Offline Patrick
« Reply #19 on: January 11, 2016, 06:02:20 PM »
Hook it to the wire that feeds the kill switch, not the coils. That's the black one into the switch, isn't it?
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #20 on: January 11, 2016, 06:32:40 PM »
That's my approach. I think its the BW.
Offline oldhatt45
« Reply #21 on: January 12, 2016, 06:05:30 AM »
MCRider,
The Black/White wire from the existing Off-Run-Off (Kill) switch is what you want to interrupt.
WHen I put in my Hondaman Relay Mods, this is one of the mods I did to put in the Off-Run-Off relay.
If you look at the diagram I've attached, look at the Off-RUn-Off relay.  You don't need any of the relay wires, you just need to look at the Black/White wire from the existing Kill (Off-RUn-Off) switch to the coils.
I hope this helps sort it out.  If not, just ask.
Charlie
« Reply #22 on: January 12, 2016, 07:49:05 AM »
MCRider,
Charlie
Thanks Charlie: That puts a cap on it. Will do next time I'm in shop. I, too, have the Hondaman HLight relays. I felt pretty proud having wired it correctly, but his instruction and jumpers left little to not understand.
Offline oldhatt45
« Reply #23 on: January 12, 2016, 07:59:28 AM »
Ron,
You're Welcome.  I know that electrical schematics can be difficult to understand for some.
Glad the diagram I attached helped out.
Charlie
PS:  I also have a diagram more specific to the K1-K4 models if you want or need it.  :)
Offline Phoenix
« Reply #24 on: January 12, 2016, 08:41:22 AM »
Charlie
Could you please post the schematic for the k1-4.  The one you posted is great.
Thanks,
Ed
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
