Author Topic: DP315 vs RC315 cam : excatly the same?  (Read 14532 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: DP315 vs RC315 cam : excatly the same?
« Reply #25 on: January 28, 2016, 04:03:37 am »
The order will go direct to a machine that will shape it and in the end ship it to me.
and then it comes over and installs it too!  ;)  ;D
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #26 on: January 28, 2016, 02:43:39 pm »
I like to change cam. + time it. Then the testride to feel the difference.
Almost same thrill to meet a woman for first time, how will she perform and how is the design ? Functional design included :)
« Reply #27 on: January 28, 2016, 02:43:47 pm »
And pays the bills and mows the lawn and then you marry it.... :o ;D
« Reply #28 on: January 28, 2016, 06:52:54 pm »
 Custom grinds should be easy these day, probably dont have to grind a master.. just move the grinding head with a stepper..
Offline stikman
  • Bit of an
« Reply #29 on: January 28, 2016, 07:24:54 pm »
I had WebCam send me some of their lobe specs.  I picked from those and have them grind me a custom cam for my auto.  It wasn't exactly easy to get the specs off them, but in the end I got enough to make a decision from.  Just a thought.
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
« Reply #30 on: January 29, 2016, 03:58:26 am »
I AM married with my bike!!
37 years since we met.  Last restore started  2012, 2014 I took her out on the streets again. I have to make up for all I did to her during the 80's. Cost some but worth it. We have so many memories and adventures together
Compare with restoring a wife... New tits, face lift, fat reduction. New bushing if giving birth several times ... 8)
Doing it despite there are younger and much hotter alternative available for less...
« Last Edit: January 29, 2016, 09:44:58 am by PeWe »
Offline gschuld
« Reply #31 on: January 29, 2016, 07:09:33 am »
George
37 years since we met.  Last restore started  2012, 2014 I took here out on the streets again. I have to make up for all I did to her during the 80's. Cost some but worth it. We have so many memories and adventures together
Might I suggest not showing that post to your wife... :o. ... ;D
George
« Last Edit: January 29, 2016, 07:11:56 am by gschuld »
« Reply #32 on: January 29, 2016, 09:47:01 am »
I'm sure she will understand :) I have not suggested any restorations.... yet:))
Skickat från min GT-I9300 via Tapatalk
« Reply #33 on: January 29, 2016, 06:30:35 pm »
At least your bike will understand and give you less #$%*!! No need to apologize either. Your bike won't cut you off either! Plus it'll never leave you or threaten to.  ;D ;)
« Reply #34 on: January 29, 2016, 06:43:48 pm »
Or sleep with your friends.... ;D ;)
« Reply #35 on: January 30, 2016, 02:54:22 am »
Exactly!!
Or nag about problems that should never be resolved. I have met several women that loved to talk about their problems. I could see the real root cause and problem solved... What a mistake.... " you don't listen ..."   bla bla..
While I have had only one bike, many women has passed thru my life. Boring to live without them too :)
« Reply #36 on: January 30, 2016, 11:44:55 am »
You mean those sonsa#$%*es, err #$%*es are the same on the other side of the big pond too?!  :o
« Reply #37 on: January 30, 2016, 03:30:01 pm »
Same on your side too? Important to let them  think that the man  ???listen....
The one I live together with now is OK. But still a woman! :)
I do not need to change woman as I change cam nowadays! ;)
I have to work more with my bike so the new cam can go in and get the numbers.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #38 on: January 30, 2016, 05:17:18 pm »
LMAO, yall too funny! ;D, You got the cam and she gets the shaft, I see, very smart!! ;D, Bill
BentON Racing Website
BentON Racing Facebook
« Reply #39 on: January 30, 2016, 08:56:12 pm »
I am so glad we dont use silicone to up lift our cams..
« Reply #40 on: January 30, 2016, 10:33:43 pm »
Don't we wish we could make a few simple adjustments to the women to improve the outlook and performance?! A few degrees advance could do wonders... adjust the timing. A new cam for higher performance... Give em bigger pistons or more of them. WITHOUT ALL THE FEEDBACK.......
A recent trick I found to be enlightening was to be with one that neither of us understood the others SPOKEN language... No arguing. No BS. Maybe we just need to swap for a while! My credentials - I only speak English. Any non-English speakers out there. Send em over and pack a new cam in their suitcase too  ;)
« Reply #41 on: January 30, 2016, 11:56:02 pm »
Constant flow of chocolate, flowers, shoes, purses and handbags...thats the common stuff to keep them happy and keep the "oil pump" flowing.
Small bore with good lubrication also important. We with CB's have understood that decades ago, go asian... :P
Womens "problems" are usually only something they like to talk about, not really solve. Enough that we  do as they say, listen not more. (Except for real tragedies that some might have encountered.)
Most important is not to never argue, become friends again is vital. If not skip it. This is what I have learned during soon 40 years of "using" them.
« Reply #42 on: February 07, 2016, 02:55:42 pm »
Compare cams.
Old RC295 copy I found and mounted last summer vs new DP315 which look a little bit fatter when comparing them. I hope it will give more fun between 8000-10.000, but still OK at low :) Lets see what the lower lift, incr duration and overlap will do.
« Reply #43 on: May 07, 2016, 02:51:01 pm »
DP315 cam installed today.
Lift: In .368" (9.35mm) Ex .367" (9.33mm)
@ 0 lash, .004" lift (1.0mm)
In 34°/65°      Dur: 279°      LC: 105.5°    Overlap:68.5°
Ex 65°/34.5°  Dur: 279.5°   LC: 105.25°
Numbers tripple checked.  0 lash achived by tighten the valve adj screw until the dial indicator needle moved a little.
Recommended lash is .012" (0.3mm)! Really? Loose 0.3mm lift?
No thanks. I set the In, Ex lash to 0.15mm (~.006")
I'm curious to hear the idle with that late IN close. Open earlier than 34° might not be the way either.
If the cam must have an open 4-1 due to the overlap. I'll start with 4-4 HM300 replica with no diffusers.
« Reply #44 on: May 07, 2016, 04:20:11 pm »
Set them at .012, it will be fine and not too noisy.
 Plus, its the recommended setting....
  My theory ..is that the clearance allows lots of oil under the rocker pad....
« Last Edit: May 07, 2016, 08:43:06 pm by 754 »
« Reply #45 on: May 07, 2016, 05:48:54 pm »
 I feel in love with some Swedish gals when I was there in 1979. ;D
« Reply #46 on: May 08, 2016, 12:00:13 am »
Me too! :) ... and the following years.... ;)
Those years were very relaxing with less global problems affecting us here.
« Last Edit: May 08, 2016, 01:07:48 am by PeWe »
« Reply #47 on: May 08, 2016, 01:02:02 am »
I thought it was to let valve sit longer in seat and transfer the heat to the seat...especially when using the upper rpms, other side of the red line where it turns green again on the CB750 tacho I have.
More oil under rocker arm pad is another good thing. All cam installations must like that. This cam has not that abrupt opening and closing curves.
The data of the 315 has plenty of overlap. Megacycle 125-20 (photo) that has very fat lobes has even less overlap. DP315 look slim when comparing them.
BUT, the duration of the 315 cam is most likely designed for the huge lash of .012" (0.3mm closest gauge I have), which is double than other hot cams).
I'll change the lash if engine runs bad in need of less duration.
I have not calculated any numbers, IN might open like the other hot cams that is in the 29-25° range @ 0 lash (5-10° later) and overlap will be less too.
I need to check with different lash. The cam might work better with more lash. I guess it will when it is deigned that way.
I have set the lash with valve cover open after I timed the cam. Easier to see when rockers are on the base circle without fiddling with a small bent feeler gauge inside the small tappet holes from one side only when valve cover is mounted.
Now 0.15mm (.0666"), next is 0.20mm (0.0787")  0.25mm (0.098"), 0.30mm (0.0118").
Change valve lash is one way to tune the cam.
Lash of IN vs EX different, the only way to make difference between IN and EX on a SOHC.
OK, I'll changed my mind when writing this. The overlap cannot work well on the street with 4-4 as it is now. I'll change to 0.30mm.  :o
Sh_t, I have to to the adjustments thru the tappet holes when  valve cover is mounted and most likely leak free.
Engine is in frame. Cut frame part not yet mounted (Frank's clamped weld free design)
I mounted the engine in frame alone. Lifted the engine without studs, cyl, head, clutch. All assembled with crankcase in frame.
What a different with new engine bolts with good threads and not banana shaped long bolts.
I have to start engine today so I'll start to adj the valves.
Back to the garage!!!! :)
EDIT: I finally understand why some experienced guys time the cam with correct running lash. Duration and overlap will then be seen as it will be.
« Last Edit: May 08, 2016, 01:24:29 am by PeWe »
« Reply #48 on: May 08, 2016, 09:39:07 am »
I can set stockers with a straight feeler... With the thicker guage bend about 13 mm to 45 degrees... Be easy to set.
« Reply #49 on: May 08, 2016, 02:03:51 pm »
Yes, I had to bend the feeler gauge. I have a smaller short one I have used before in the 80's. Now bending the thicker one. I used the 0.25mm (light fit) when it bent a little and might be in an angle making more lash. The new valves (+ guides ) have new lash caps and lash might become bigger after some use.
Did not complete today.  Start it tomorrow.
