Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 187599 times)
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
Re: 1974 Honda CB550 Build. "BlacSOHC"
« Reply #275 on: June 20, 2016, 02:41:24 PM »
Which length Hagons did you get?
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline BLAC
  • An espresso is a
« Reply #276 on: June 20, 2016, 03:39:52 PM »
I'm not sure off the top of my head.  I called Hagon and told them it was for a CB550 and gave them my weight (180 lbs) and they sent me springs.  I will measure when I get home, but they should be stock length.  The reason they might be a little short in my case is because I moved the mounting position forward.
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline joeyvans
  • Definitely not a
« Reply #277 on: June 20, 2016, 03:46:30 PM »
It does look like a somewhat serious angle, even without any compression. It looks awesome though.... Hope it works!
1976 CB550 K2
Offline BLAC
  • An espresso is a
« Reply #278 on: June 20, 2016, 04:47:23 PM »
Thanks! ya I think it is coming together nicely!  I have measured everything 100 times all of the mounting points and angles are all even!  It's a good feeing  ;D
« Reply #279 on: June 20, 2016, 05:04:39 PM »
Let's keep fingers crossed for clearance, since the subframe looks tidy.  How did you join your upper rails to the existing frame?
Offline BLAC
  • An espresso is a
« Reply #280 on: June 20, 2016, 06:17:55 PM »
I filed down some chromoly tubing to be a press fit into the stock frame and the loop bar.  It took a while but it fits PERFECT.  I had to tap the loop on with a rubber mallet.  I drilled a hole and spot welded it on each side so it should be very strong.
« Reply #281 on: June 20, 2016, 07:47:07 PM »
Cool.
Offline BLAC
  • An espresso is a
« Reply #282 on: June 23, 2016, 03:17:36 PM »
To measure clearance while it is still tacked up (not fully welded) would you suggest I leave the top of the springs disconnected and move the swingarm with the wheel as close to full range of the spring to make sure it doesnt hit?
I just dont want to bolt it all together and start jumping on it and potentially bend or break the tacks.
does that make sense?  It doesnt feel very scientific, but I think I could eye ball the travel pretty close...
Offline Denver_Larry
« Reply #283 on: June 23, 2016, 04:59:31 PM »
Certainly, I would figure out what the compressed length of the shock is (center of mounting hole to center of mounting hole) and mock it all up with the wheel and tire if you are worried about clearance.  get everything assembled and use a tiedown or something to hold the wheel up while you match and confirm the distance between the upper and lower mounts.
2005 RC51
1973 CB350F...project
Offline riverfever
« Reply #284 on: June 24, 2016, 09:26:43 AM »
That looks wonderful. For some reason my eye is always really critical of the line from seat to tank. You've really taken your time and thought things through. It shows.
Offline BLAC
  • An espresso is a
« Reply #285 on: June 24, 2016, 10:10:37 AM »
Thank you I appreciate that!  I am like you and hate it when that joining area looks wonky or when the "cafe racer seat" that someone buys and screws onto the stock frame looks like it is sitting on top of the bike instead of being a part of it.
This is the first bike I have ever built, so I really am taking my time to make sure I get it how I want AND to make sure I dont make too many stupid mistakes
« Reply #286 on: June 24, 2016, 10:22:45 AM »
Someone hasn't adjusted to Hawaiian time (6:26 am).
Offline BLAC
  • An espresso is a
« Reply #287 on: June 24, 2016, 06:21:41 PM »
Gotta keep your nuts clean!  ;D just got these new fork end caps from Honda!
devil is in the details.
Offline Camrector
« Reply #288 on: June 24, 2016, 08:21:16 PM »
Wow how's that for vanity!! Selfie fork end caps!
Offline BLAC
  • An espresso is a
« Reply #289 on: June 24, 2016, 09:29:16 PM »
So I can stare at myself while I'm riding!!! :P
Offline BLAC
  • An espresso is a
« Reply #290 on: June 25, 2016, 12:54:22 AM »
Low...rye...duh...
I did some measuring and my Hagon shocks are going to be too short with this subframe, but it looks like they have some that are perfect... Now I just have to hope they might exchange them  ::)  :-X
« Last Edit: June 25, 2016, 12:56:00 AM by blacSOHC »
Offline riverfever
« Reply #291 on: June 25, 2016, 01:54:11 AM »
It's killing me dude. I'm up super early drinking coffee and plotting where I'll cast my line. Tonight I'm up late trying to unwind from the long day with the vintage Porsche. I got good stories.
Offline redwillis1978
« Reply #292 on: June 25, 2016, 06:13:59 AM »
Low...rye...duh...
Time to purchase some 17-inch wheels dude.
Offline BLAC
  • An espresso is a
« Reply #293 on: June 25, 2016, 12:36:20 PM »
Low...rye...duh...
i want to run 18's and just buying the correct length springs would also be infinitely cheaper than having buchanans make another wheel for me (and buying a tire)
In this photo I am just measuring out the point where the rear tire will bottom out.  It happened when the mounts are 10.25" apart (center of eye to eye)
« Last Edit: June 25, 2016, 01:41:16 PM by blacSOHC »
Offline calj737
  • I refuse...
« Reply #294 on: June 25, 2016, 02:57:41 PM »
That does not reflect a true bottom of shock compression as there is no Rider weight calculated. Worst case, longer shocks are needed.
Offline BLAC
  • An espresso is a
« Reply #295 on: June 25, 2016, 05:44:25 PM »
I'm not sure I understand.  My thinking is that if I can find the fully compressed and "bottomed out" length of the shocks, it won't matter what my weight is as there would be no more room for it to travel anyway.  I see how my weight and the weight of the motor would effect "extended" and static ride height, but not sure how my weight would make the shocks travel farther than the "fully compressed" length.
Offline Camrector
« Reply #296 on: June 25, 2016, 06:34:26 PM »
Pm sent
« Reply #297 on: June 25, 2016, 06:54:51 PM »
Maybe it's the angle of the photo, but it looks like the swing arm angle at ride height would need to angled way down. By the time you got to this point the chain would have slacked off the sprockets and amputated you left foot.
Offline BLAC
  • An espresso is a
« Reply #298 on: June 25, 2016, 07:43:00 PM »
The swing arm at ride height is angled slightly less down than a factory bike.
« Reply #299 on: June 25, 2016, 09:12:54 PM »
Probably just the picture.
