Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 183542 times)
0 Members and 13 Guests are viewing this topic.
Offline 540nova
Re: 1974 Honda CB550. Monoshock. "BLAC"
« Reply #400 on: January 09, 2017, 01:24:55 PM »
A black painted or powdercoated Tarozzi brace is hardly noticeable. I have one on my 450.
« Reply #401 on: January 09, 2017, 01:45:06 PM »
Agreed, but everyone has their opinion.
Offline BLAC
  • An espresso is a
« Reply #402 on: January 09, 2017, 02:06:17 PM »
That is by far my favorite that I have seen.  My problem is without running gators it can look a little chunky, especially as the only black piece I will have down there, I fear it may stick out.  That and not being close enough to the tire to allow for me to get the fender as low as I want it without creating some sort of spacer off the bottom...
I will keep this on the back burner as I get the rear suspension and frame together!
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
« Reply #403 on: January 09, 2017, 02:09:51 PM »
It may look "clunky" to someone who hasn't got a clue about motorcycles but, I can garantee you that anyone that does know a bit will appreciate it, its not just about looks...!!!   ???
« Reply #404 on: January 09, 2017, 02:26:30 PM »
There is other ways, for one he could form the fender brace, in 2 pieces like I suggested, and join the middle...out of 1/4 alloy..or dragbike style.... You can make it yourself or with minimal lathe work.
The one on the left a member here made, i described what to do and he made it.
« Last Edit: January 09, 2017, 02:28:05 PM by 754 »
Offline calj737
  • I refuse...
« Reply #405 on: January 09, 2017, 03:09:52 PM »
Don's bike does look great. Personally, I like your initial idea with Cliff's fender of running two stainless rods up and over the fender. Tie them together at the forks, and to each other above the fender, and you're as good (if not better) than stock.
« Reply #406 on: January 09, 2017, 04:52:37 PM »
Don't be so focused on aesthetics that you lose sight of function (primary concern).  Form will follow function.
This is my 750 with no gaiters and a Telefix fork brace
Offline BLAC
  • An espresso is a
« Reply #407 on: January 09, 2017, 05:51:58 PM »
Yep, This is what I had in mind, i just didnt know what to look up to see examples, thanks for the link!
@cal, you are totally right, I'm not going to sacrifice any performance/function for just pure aesthetic, but I am going to do by best to solve for both.  Your bike is a beaut by the way!
Offline calj737
  • I refuse...
« Reply #408 on: January 09, 2017, 05:57:17 PM »
Here's an elegant option too-
Offline riverfever
« Reply #409 on: January 09, 2017, 06:49:05 PM »
Love that.
Offline 540nova
« Reply #410 on: January 09, 2017, 06:59:59 PM »
I powdercoated mine, I think it blends right in.
Offline 540nova
« Reply #411 on: January 09, 2017, 07:01:12 PM »
That's going on my CB350
Offline BLAC
  • An espresso is a
« Reply #412 on: January 10, 2017, 10:16:20 AM »
This was my initial plan, but to keep those rods closer to the fork so they don't flare out to the very front and back of the fender.  But I don't know how much actual structural strength this solution would have it looks like it is more of a cosmetic solution?
« Reply #413 on: January 10, 2017, 10:51:21 AM »
Those rod mou ts aint gonna brace the fork much.
« Reply #414 on: January 10, 2017, 12:00:56 PM »
Agreed. The rods will not provide any real support as a fork brace and only serve to keep the fender in position.
Offline calj737
  • I refuse...
« Reply #415 on: January 10, 2017, 12:16:09 PM »
Which is why I susggested they tied together above the fender ala stock fender bracket.  :)
Offline BLAC
  • An espresso is a
« Reply #416 on: January 10, 2017, 01:36:04 PM »
is anyone familiar with this guy's video? If so do you think it is correct/good information? I am pulling my head off soon and will be sending it out to Mr Rieck, I'm thinking it would be a nice reference to watch while working (along side the shop manual).
Offline Restoration Fan
  • My wife will never call me
« Reply #417 on: January 10, 2017, 03:12:13 PM »
Don,
Did you sell the 750 or are you still holding onto it so that I can ride it the next time I come to LA?  ::)
« Last Edit: January 10, 2017, 03:14:43 PM by Restoration Fan »
« Reply #418 on: January 10, 2017, 03:13:58 PM »
I watched it a long time ago.  I don't remember any glaring mistakes but I also don't remember being super impressed by it either.  I recommend you look at the pinned thread at the top that Dino did on his Hackaweek channel.  It is very thorough and well documented in video format.  Follow his lead and you'll do well.
Edited to add:
Yes, I realize Dino's is a 750 but it's not incredibly different.  Cam towers are different and the rocker arms are held differently but the concept is the same.
« Last Edit: January 10, 2017, 03:16:36 PM by Restoration Fan »
« Reply #419 on: January 10, 2017, 03:16:19 PM »
Speaking of pins, you should upgrade to the later model head cover that had the upgraded rocker pins.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #420 on: January 10, 2017, 03:19:28 PM »
+1 My early '76 valve cover was #$%*e.... so I swapped a better looking '74 I had on a spare motor. Guess what... that one was #$%*e too.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline riverfever
« Reply #421 on: January 10, 2017, 04:02:36 PM »
Well you don't have very good luck.
« Reply #422 on: January 10, 2017, 04:05:24 PM »
Don,
I traded it for the new Thruxton R.
Offline BLAC
  • An espresso is a
« Reply #423 on: January 10, 2017, 05:58:36 PM »
Ahhhh I forgot I read that a long time ago.. back to the "parts wanted" thread...  :-\
My bike only has 8k original miles on it, should I just replace it with a pinned cover even if it is not starting to wear either way?  I just don't want to buy a late model valve cover with the pins in worse shape than my current one.  :o
« Last Edit: January 10, 2017, 06:06:46 PM by BLAC »
« Reply #424 on: January 10, 2017, 06:34:10 PM »
How do you tell the late model valve cover from the earlier ones?
I have 3 extra valve covers but I don't know how to tell the difference.  Do any of these 3 fit the 'late model' classification?
