Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 179581 times)
0 Members and 12 Guests are viewing this topic.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: 1974 Honda CB550. Monoshock. "BLAC"
« Reply #475 on: January 20, 2017, 05:09:19 am »
Allow me to be the 1,294th person to say it.... Nils is the man and vapor blasting is amazing...
Are you kidding me, this is amazing...
This might be the straw that broke the camels wallet.. I might have to split my case and send it off to get beautified
            Wow, That DOES do quite the job, on those parts! I am impressed!  8)
Member # 1969
« Reply #476 on: January 20, 2017, 06:20:07 am »
I sent my H2 cases to him along with the cylinders and heads....no regrets!
Offline Restoration Fan
  • My wife will never call me
« Reply #477 on: January 20, 2017, 10:11:39 am »
Yeah, I've already spoken with Nils about it but I'll definitely be sending him the pieces of the 550 engine in the not-too-distant future.  Nils does fantastic work.
Offline BLAC
  • An espresso is a
« Reply #478 on: January 20, 2017, 10:47:59 am »
My fear is the regrets I get while trying to reassemble and the cost of a million new gaskets, bushings and bearings...  :'(
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline calj737
  • I refuse...
« Reply #479 on: January 20, 2017, 11:01:42 am »
Your bigger fear should be finding out afterwards that you should have...  :(
Offline BLAC
  • An espresso is a
« Reply #480 on: January 20, 2017, 11:17:07 am »
True.. Ok, you have persuaded me, I'm going to do it.
plz send Top Ramen
« Reply #481 on: January 20, 2017, 11:20:18 am »
All that and a pack of Skittles, too!  8)
Offline BLAC
  • An espresso is a
« Reply #482 on: January 20, 2017, 12:49:52 pm »
I also sent him my cylinder and head but that went on to Mike Rieck... I hope he got skittles in that one too ;)
Offline GV1390
  • Express Gratitude.
« Reply #483 on: January 20, 2017, 12:54:46 pm »
The only way to do it.
93' GSX-R1100, 78' CB550, 71' CL350, 71’ CB500 & 02' ZRX1200R.
Offline BLAC
  • An espresso is a
« Reply #484 on: January 20, 2017, 04:28:51 pm »
Now that the case is coming apart...
I'm thinking lightened/balanced crank by APE and shot peened and balanced rods... then I think I would have a nice fun setup?
Offline BLAC
  • An espresso is a
« Reply #485 on: January 20, 2017, 04:31:23 pm »
Also, I bought 2 more gas tanks for mock ups, one of them is a late model (supersport?) tank....
I think I like the original tank shape more, but im undecided, what do you guys think?
Offline calj737
  • I refuse...
« Reply #486 on: January 20, 2017, 04:32:04 pm »
Save the money and buy REALLY GOOD shocks. Those will produce a better motorcycle than some internal tricks will. And every mile you ride you will take advantage of the premium suspension far more than some upper end HP gains.
Offline BLAC
  • An espresso is a
« Reply #487 on: January 20, 2017, 04:49:09 pm »
I will have a custom built monoshock from Racetech and currently have the Racetech springs and gold valve emulators up front with brand new TNK fork tubes.
I originally wanted to do inverted forks up front but I decided I want to keep the look of the original forks.
I am am also going to have Racetech dial in the front end setting (dampening, preload and static sag) while its in their shop, so I think the suspension should be pretty nice once it is all together.
Is there another route you would suggest while keeping the stock forks?
« Reply #488 on: January 20, 2017, 05:47:33 pm »
You should probably dial in those preload/static suspension settings once the bike is complete including the weight of you & your gear.
Offline BLAC
  • An espresso is a
« Reply #489 on: January 20, 2017, 05:58:14 pm »
Ya, and I don't even have the head/cylinder back. It will be 2 trips, fortunately they are only 45 mins away =)
« Reply #490 on: January 20, 2017, 09:07:37 pm »
Another option to consider is a conventional (right-side-up) set of R6 forks (1998-2004).  2003-2004 offer the best spec - 43 mm telescopic fork w/adjustable preload, compression and rebound damping.  You can run a single brake disc that will be lighter than stock, handle better than stock and brake better than stock.
Offline riverfever
« Reply #491 on: January 21, 2017, 07:54:51 am »
Blac I have always liked the look of the Supersport tank but I prefer the orange tank and how it flows with the lines of the seat you have better. This is really going to be a head turner when you're done.
Offline BLAC
  • An espresso is a
« Reply #492 on: January 21, 2017, 11:31:23 am »
I agree with you, I like the early K tank better, it feels a lot more elegant than the super sport, especially in relation to the shape of the seat cowl.
I bought another early tank that I'm going to start chopping up testing a few ideas with knee dents and the like.  I'll post pics when I have something to show
Offline bill440cars
« Reply #493 on: January 21, 2017, 05:49:26 pm »
           Just now seeing this and have to agree that the orange tank really adds a lot to the build. Good, to have at least 2 different tanks, to really see just how it would look, which is better than trying to picture it (at least, with my mind, it is better to actually see the difference. LOL  :D
Member # 1969
Offline BLAC
  • An espresso is a
« Reply #494 on: January 22, 2017, 12:42:19 am »
As you may have noticed, I fell out of love with the position and angle of the subframe braces I originally made.  So I cut the tacks off of it, threw them to the side and bought another 30" of 7/8 chromoly pipe online.
I spent the last 4 hours getting them exactly how I want them and all fitted up nicely.  I am really happy with the shape now. Tomorrow I hope to make mounts for the monoshock and chop up my spare tank to see what I can make =)
« Last Edit: January 22, 2017, 12:45:35 am by BLAC »
Offline sethmcalister
« Reply #495 on: January 22, 2017, 01:26:17 am »
👍100%
Sent from my Nexus 6P using Tapatalk
Offline 540nova
« Reply #496 on: January 22, 2017, 05:55:04 am »
 Is that a Meyerbuilt cowl?
Offline calj737
  • I refuse...
« Reply #497 on: January 22, 2017, 06:48:07 am »
Looks like Ian Halcott perhaps?
Offline bill440cars
« Reply #498 on: January 22, 2017, 07:25:29 am »
           You know, that does give it a whole new look. Glad you went with your "2nd" thoughts. Can't wait to see the finished product and hear about the "Shakedown" run.  8) ;)
Member # 1969
Offline BLAC
  • An espresso is a
« Reply #499 on: January 22, 2017, 09:51:43 am »
Yes it is from Cliff Meyers.  He also built the front fender (which I forgot to lay on the tire for the picture  :-\)
