Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 183598 times)
Offline calj737
  • I refuse...
Re: 1974 CB550. Monoshock. Engine Build. "BLAC"
« Reply #675 on: February 10, 2017, 05:20:53 PM »
Yeah, those law-abiding, government-fearing, sissy pants guys don't scare me none! But, alas, I don't drink beer anyway. I'm a dark rum guy if and when I drink. I did have 2 4 fingers cocktails tonight in fact (first in over a year) to watch the supermen/eclipse with my kids. Frickin' clouds...
Offline BLAC
  • An espresso is a
« Reply #676 on: February 10, 2017, 05:28:26 PM »
Ah no fun! well it is just as crappy out here in LA, constant downpour all day.
Good night to spend in the shop, I'm hoping to rebuild the oil pump with Elan's kit =)
« Last Edit: February 10, 2017, 05:45:44 PM by BLAC »
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Online RAFster122s
« Reply #677 on: February 11, 2017, 01:37:39 AM »
AntiSieze.
Dow Hi Temp brake grease.
Red LocTite (motor/exhaust studs)
DOT 3 brake Fluid.
Acetone.
More beer.
The DOW High Temp grease is a High Temp Vacuum & Petcock Grease used in lab work. Ebay sellers will sell you a small container of it or you can go for a big tube. It has an expiration date...don't know what that means with respect to the product performance or suitability.
The Brake Assembly Lube can be bought at NAPA...Silicone used on backs of pads and hardware, piston and seal get the Assembly Lube of course... never want the silicone to contaminate the fluid. The Dow stuff will not migrate or melt at operating temps or above operating temps until it get extremely hot (your brakes would be boiling if it were to attempt to reach that temp...)  So, because it won't melt and run it is ideal for the application.
TwoTired was very wise and he wrote up an excellent brake how to...worth looking up.
David
Offline BLAC
  • An espresso is a
« Reply #678 on: February 13, 2017, 01:54:45 PM »
Im guessing this isn't good?  ???
Offline BLAC
  • An espresso is a
« Reply #679 on: February 13, 2017, 02:10:20 PM »
I'm guessing it's just a one off Honda + Yosimura put together as a test unit on this bike...  ;D
I'll probably replace the rotor with a stock one, what are the options for bolt on upgraded charging systems? Ricks doesn't look like they make a kit for the 550?
Offline calj737
  • I refuse...
« Reply #680 on: February 13, 2017, 02:14:06 PM »
No aftermarket exists for the rotor. What's the inside of the cover look like? I wonder if the damage isn't so bad that you could turn it on a lathe? I know many of the HiPo guys run a lightened rotor, but not sure what effect that has on our anemic charging system  :-\
Offline BLAC
  • An espresso is a
« Reply #681 on: February 13, 2017, 02:19:46 PM »
I just did more research and came back to delete my silly question of whether there were aftermarket options but you caught it before I could haha it looks like the question has been answered a million times..
Here are the rest of the guts:
« Last Edit: February 13, 2017, 02:22:54 PM by BLAC »
Offline BLAC
  • An espresso is a
« Reply #682 on: February 13, 2017, 02:21:34 PM »
It's really odd. A couple of them have hardly any mark on them, others have the mark but you can't "feel it" others actually have a small gash that you can feel with your nail...  ???
Offline Bootsey
« Reply #683 on: February 13, 2017, 03:48:27 PM »
Sorry, I might have the wrong idea here, but are you talking about the groove around the circumference in the centre of the rotor?
If so, mine's exactly the same (I saw no indication it was from undue damage) & I was under the (possibly mistaken) impression it was something from the production process - maybe something to do with balancing?
I think I remember Dave500 posting about this at some stage, but it's rather difficult to revive some of the past threads these days, even with Google advanced search.
Maybe worth checking with some other 550 owners to see if it's a sometimes a normal occurrence?
Edit : http://forums.sohc4.net/index.php?topic=133777.0
Mostly talking about the butt joint, but you can also see the gouge present.
« Last Edit: February 13, 2017, 03:55:01 PM by Bootsey »
Offline Camrector
« Reply #684 on: February 13, 2017, 03:58:48 PM »
http://electrexworld.co.uk/acatalog/RPK-1550_Honda_CB500_CB550_-_Alternator_System.html
I bought this
Came in 4 days. I also have a rebuilt Ricks stock coil and rotor if you need.
Offline Camrector
« Reply #685 on: February 13, 2017, 03:59:43 PM »
Yes an aftermarket rotor exists Cal!! ;D
Offline jonda500
« Reply #686 on: February 13, 2017, 04:01:48 PM »
That rotor is quite normal, something to do with the manufacturing process - my three look similar, John
A starter clutch thread:
« Reply #687 on: February 13, 2017, 04:08:17 PM »
I bought this
I remember Cal posting that link a year or two ago. Too bad it's not for a 650!!  ;)
Offline BLAC
  • An espresso is a
« Reply #688 on: February 13, 2017, 04:13:11 PM »
Thanks for that, I was thinking it HAD to be in manufacturing because nothing is touching and there are no marks anywhere on the coil at all.. that makes me feel better.
ONWARD!
Offline calj737
  • I refuse...
« Reply #689 on: February 13, 2017, 04:45:37 PM »
That system is more than a Rotor, Cam. It's a complete charging system, coils and stator. It is quite trick looking. There's some concern that it won't charge at low RPMs for daily driving etc as it's really targeted towards road race use. It also allows the omission of the battery altogether, though that presents other problems for our bikes in a street application. It surely wouldn't support an M-Unit without a battery.  :)
Offline BLAC
  • An espresso is a
« Reply #690 on: February 13, 2017, 04:50:51 PM »
Speaking of Motogadget... I placed my order on Wednesday and I just received notification that a "package with german writing on it" was delivered. Insane shipping speed for international, right?
ok, time for me to sneak out of work early and play with my Motoscope Pro!
« Last Edit: February 13, 2017, 05:00:13 PM by BLAC »
Offline Restoration Fan
  • My wife will never call me
« Reply #691 on: February 13, 2017, 06:36:50 PM »
(I'm not above sneaking it through the mail to you unlike the goody-2-shoes on this site)  ;D :P
So I spend the weekend away with my wife and it felt like my ears were burning the whole time.  I think I just found out why!  ;)
Offline BLAC
  • An espresso is a
« Reply #692 on: February 13, 2017, 06:49:45 PM »
It was all a test, I have family in law enforcement.  I'm just glad I didn't have to turn you in!  :P
Offline BLAC
  • An espresso is a
« Reply #693 on: February 13, 2017, 08:01:49 PM »
I didn't realize how little the breakout box is  :o
Beautiful!
Offline BLAC
  • An espresso is a
« Reply #694 on: February 13, 2017, 08:08:57 PM »
Um... not sure why that last picture looks like I have a nub for a pinky... I have all my fingers.. that is really strange  :o ;D
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #695 on: February 13, 2017, 08:20:16 PM »
That's good, because the "Finger Length Admins" are probably pretty tough around here.  :)
Offline BLAC
  • An espresso is a
« Reply #696 on: February 13, 2017, 09:18:02 PM »
Hahahaha I was more personally confused as to why I was missing a Finger in that pic
« Reply #697 on: February 14, 2017, 12:14:07 AM »
Blac,
Are you not using a m-unit? I was wondering since you have a breakout box.
Offline BLAC
  • An espresso is a
« Reply #698 on: February 14, 2017, 12:18:22 AM »
Blac,
I am using an M-Unit, it was my understanding that to get the lights to display on the motoscope (turn signals, oil switch, etc) they had to be run to the breakout box?  ???
« Reply #699 on: February 14, 2017, 12:19:37 AM »
Blac,
Sounds like a good question for Motogadget customer service aka Cal.
