About that engine...
Cleaned and lubed:
Sealed up and shifter bits installed:
Pistons joining the party:
What a stud(s):
This is where things took a turn (briefly).... I was down to installing THE LAST case bolt.. the long one at the back left corner, but for some reason it wouldn't go all the way in and it wouldn't catch any threads. It felt like the bottom half of the hole was filled with Hondabond.. i shined a light down into it, but it just looked like the whole ended before the threads started, but again, the bolt was hitting a rubbery surface, it wasn't hitting metal.
Now I'm sure that I accidentally dropped a dowel, gasket of SOMETHING in there and I'm going to have to pull the cases back apart to see what is going on. Before doing that and after scratching my head for an hour, I finally tracked down a long skinny screw. Being low on patience and other options, I drove the screw into this mystery and once anchored, I used a claw hammer to pull it to the surface..
I'm just as confused as ever.. I have never seen this little bastard before in my life. I hope it wasn't supposed to be in there, because i destroyed it while removing it...
Anyway, that's where she sits!
