Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 209657 times)
Offline BLAC
  • An espresso is a
Re: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"
« Reply #850 on: April 24, 2017, 03:47:27 PM »
Haha nice selfie bro!
i think it was well framed  8) :P
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
« Reply #851 on: April 24, 2017, 09:26:19 PM »
You can also tap in swingarm spools (see them on several bikes like riverfever's) so you can use a paddock stand.
« Last Edit: April 24, 2017, 11:54:34 PM by SOHC4 Cafe Racer Fan »
Offline BLAC
  • An espresso is a
« Reply #852 on: April 24, 2017, 09:48:12 PM »
thats the idea! im looking at some pitbulls on craigslist
Offline innovativems
    • Innovative MotoSports
« Reply #853 on: April 25, 2017, 07:02:13 AM »
I run a pitbull with my cb's.  You can just use the flat arms on the stands to go under the swingarm too.  It's pretty sturdy.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Godffery
  • Godffery's Garage
« Reply #854 on: April 25, 2017, 08:22:24 AM »
I've done that on a few projects and it works rather well.
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Cafe+Overkill/CafeOverkillDSC_062.JPG.html
« Reply #855 on: April 25, 2017, 08:48:52 AM »
I like the swingarm spools on Godffery and riverfever's bikes.  I think having a more positive hook-up on a spool is safer than just using the flat portion of the swingarm resting against the stand.  I'm sure it works, but in California we have earthquakes. ;)
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #856 on: April 25, 2017, 09:05:46 AM »
I am also installing spools on my 550... and hopefully tonight.
The left side flat arm on my paddock stand is starting to bend downwards because of the added pressure on that side whilst standing the bike up. Will feel much more comfortable with spools installed.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline riverfever
« Reply #857 on: April 25, 2017, 08:00:33 PM »
I really like that new stand I picked up from Cycle Gear but supporting it from underneath the swingarm just isn't ideal (it's got both a swingarm mount and a spool mount). The spools end up in the perfect spot and it's so much more stable. I stole the idea from Dave Barbier but I did go with Woodcraft spools instead of less expensive eBay ones because they use an 8mm bolt but the spool is still the same diameter regardless if you get the 8mm or 6mm bolt. .
Offline BLAC
  • An espresso is a
« Reply #858 on: April 26, 2017, 12:58:36 AM »
Great info! I have my shopping list put together.  I'll check out you thread (or look up the person you got the idea from) to get pics of where you mounted the spools  8)
In other news I made a lot of progress on the motor last night.  Pics to come in the AM
Offline riverfever
« Reply #859 on: April 26, 2017, 04:48:18 AM »
I should also add that the Woodcraft spools (in either 6 or 8mm) use the exact same spool itself which is very nice on our bikes because the spool diameter is the same and space is at a premium down there between the welds. If you would like any measurements let me know.
Offline BLAC
  • An espresso is a
« Reply #860 on: April 26, 2017, 10:09:35 AM »
About that engine...
Cleaned and lubed:
Sealed up and shifter bits installed:
Pistons joining the party:
What a stud(s):
This is where things took a turn (briefly).... I was down to installing THE LAST case bolt.. the long one at the back left corner, but for some reason it wouldn't go all the way in and it wouldn't catch any threads.  It felt like the bottom half of the hole was filled with Hondabond.. i shined a light down into it, but it just looked like the whole ended before the threads started, but again, the bolt was hitting a rubbery surface, it wasn't hitting metal.
Now I'm sure that I accidentally dropped a dowel, gasket of SOMETHING in there and I'm going  to have to pull the cases back apart to see what is going on. Before doing that and after scratching my head for an hour, I finally tracked down a long skinny screw.  Being low on patience and other options, I drove the screw into this mystery and once anchored, I used a claw hammer to pull it to the surface..
I'm just as confused as ever.. I have never seen this little bastard before in my life. I hope it wasn't supposed to be in there, because i destroyed it while removing it...
Anyway, that's where she sits!
« Last Edit: April 26, 2017, 10:14:47 AM by BLAC »
Offline koendd
« Reply #861 on: April 26, 2017, 10:24:50 AM »
funny #$%*!
looks like the cap of a hondabond/sealer tube
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline BLAC
  • An espresso is a
« Reply #862 on: April 26, 2017, 10:32:58 AM »
That's what I thought when I pulled it out too, I pulled it out and immediately looked for my HondaBond to make sure I didn't do something stupid and put the cap in there haha.. but it is really rubbery and semi translucent..
Offline BLAC
  • An espresso is a
« Reply #863 on: April 26, 2017, 10:38:41 AM »
Dude! Now you're screwed... that cap is supposed to be in there  ::) Stinking amateur wannabe motor builders! You could screw up a 2-car funeral or tear up an anvil with a rubber mallet. Start over please and put that back where it belongs, cemented in place with Permatex.
Geez my patience is wearing thin-  8)
 ;D ;D ;D I do what I can!
but... that isnt supposed to be in the motor at all.. is it? I have looked at 3.2 million engine schematics and forum threads and can not find a mention of this thing.
The only thing I can think of is maybe it is a cap used to protect threads when vapor blasting?
« Last Edit: April 26, 2017, 10:41:54 AM by BLAC »
Offline BLAC
  • An espresso is a
« Reply #864 on: April 26, 2017, 10:43:13 AM »
It's from the uber-rare Sandcast 550 cases, made only 1 day in the month of April, and only 19 documented cases had it. You've just devalued that bike immensely. Please erase that post, put it back, and Trey pretend like it never came out. We won't tell when you go to sell it  ;)
No, doesn't belong, and no, it's not from Vapor Blasting either.
 ;D ;D ;D ;D
Offline BLAC
  • An espresso is a
« Reply #865 on: April 26, 2017, 10:59:08 AM »
Mystery solved, it was a thread/hole protector from the vapor blasting process.
I might have blown it in farther down into the hole with my air compressor, but either way I should have chased the threads and found it earlier.
All good, mystery solved  ;D
« Reply #866 on: April 26, 2017, 10:30:51 PM »
That's just mean!
Offline BLAC
  • An espresso is a
« Reply #867 on: April 26, 2017, 10:39:52 PM »
That's just mean!
Such a nice guy, right?!  ;D
Offline BLAC
  • An espresso is a
« Reply #868 on: April 26, 2017, 10:53:53 PM »
Cylinder is on and pistons are sittin pretty!
Offline Restoration Fan
  • My wife will never call me
« Reply #869 on: April 27, 2017, 12:04:25 AM »
Man, that engine looks good!  Great job on this bike, Bryan!
Offline BLAC
  • An espresso is a
« Reply #870 on: April 27, 2017, 10:03:47 AM »
Thanks Ron!  I am about to put your valve cover to work once I need to degree the cam.  I will engrave "Restoration Ron's Good Karma Cam Cover" on it and over it up to other 550 owners once it is milled out =)
thanks again!
Offline joeyvans
  • Definitely not a
« Reply #871 on: April 27, 2017, 10:25:07 AM »
thanks again!
So you got yourself a Mega 126-00 cam?
1976 CB550 K2
Offline BLAC
  • An espresso is a
« Reply #872 on: April 27, 2017, 10:37:42 AM »
I think I'm going with the 126-20  ;D
« Reply #873 on: April 27, 2017, 03:05:33 PM »
Nice job...no matter what Cal says!
Offline Camrector
« Reply #874 on: April 27, 2017, 05:00:52 PM »
I'm pretty sure I've mentioned it before, just make sure those valve reliefs are big enough for the 126-20. They don't appear to be now.
