Author Topic: The large fittings on the oil tank - what do you use to tighten them?  (Read 2344 times)
Offline SKTP
So I am reassembling my 78K for the 2nd time...the first time, I had trouble tightening down the large "nuts"/fittings that connect to the actual oil tank. It's hard to get a tool in there...I thought I would be smart and tighten them before putting the tank in, but that is impossible to then put the tank in the frame...is there some sort of thin wrench that I am not aware of for this task? I did end up using long thin vice grips but that let some score marks. I can live with them, but there's got to be a better way?!
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline mystic_1
  • 1970 CB750K
Re: The large fittings on the oil tank - what do you use to tighten them?
« Reply #1 on: January 25, 2016, 03:50:35 PM »
You can remove the battery tray to gain access to the tank from the backside, that makes it a bit easier.  Still a PITA though.
Working from behind there's usually enough room to make a small turn, flip your wrench over to get a different angle, another small turn, flip wrench, etc.
This is assuming you're using a standard open-end wrench with an angled head.
mystic_1
- John Augustus Shedd
Offline SKTP
« Reply #2 on: January 25, 2016, 04:42:20 PM »
Yes...It is a pain in there...I just wanted to confirm that I am not missing something obvious...I did tighten with battery box out...then that was a pain to get in with the oil tank in place...had to take off the 3 mounting screws. I think all is well...
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #3 on: January 25, 2016, 06:10:39 PM »
Croissant wrench. ... A French tool..
Offline cb650PK
« Reply #4 on: January 25, 2016, 06:14:15 PM »
Works better when accompanied by good coffee.
S CB750 na vecne casy a nikdy jinak.
Offline rddcw
« Reply #5 on: January 25, 2016, 07:06:26 PM »
This is what I use  :)
Offline Restoration Fan
  • My wife will never call me
« Reply #6 on: January 27, 2016, 01:26:20 AM »
I used a combination on my 78K.  We used a crescent wrench (err...excuse me...a croissant wrench) on one of the nuts but I think we used a long, open ended wrench on the other one.  I don't remember the size but it's one of the bigger ones...about a 17mm maybe?
« Reply #7 on: January 27, 2016, 05:32:30 AM »
Yes  ;)
    • http://forums.sohc4.net/index.php?PHPSESSID=mnknpa7m5unf66m0fnm78ir5u5&/topic,60973.0.html
« Reply #8 on: January 27, 2016, 09:17:14 AM »
use a svedish key..made by bacho...is it only in denmark ve call them svedish??
« Reply #9 on: January 27, 2016, 05:50:39 PM »
crescent wrench is a whitworth socket set
« Reply #10 on: January 28, 2016, 02:40:42 AM »
And what do you call this wrench?
Offline 72 yellow
« Reply #11 on: January 28, 2016, 05:56:25 AM »
It's a special wrench used to tighten a lead pipe cinch and also to adjust a canutin valve.
« Reply #12 on: January 28, 2016, 06:08:31 AM »
We call it the French wrench for some reason.
Offline mystic_1
  • 1970 CB750K
« Reply #13 on: January 28, 2016, 03:55:16 PM »
Since we're on to tool names, these are "crows feet wrenches", or "crows feet sockets".
Part of the problem with using a regular Crescent Wrench for this job is that the ones that are big enough to fit onto the fitting are usually 10 inches long or more.
One of these might make things considerably easier:
Another thing to keep in mind is that these fittings don't need to be super-tight.  There are aluminum crush washers that go inside the fittings and provide the seal against the tank bungs.  Replace these!  They're super-cheap!  Using fresh crush washers, tighten these to the same degree that you would an oil drain plug.
mystic_1
