Author Topic: mr electrical coils on ebay  (Read 1174 times)
« on: January 26, 2016, 09:43:47 PM »
 Has anyone tried these coils? Just curious, the price is good. I'd assume they were made with cheap labor $18.XX each and have coil towers so wires can be installed and changed.  I'm wondering about the ohms.
http://www.ebay.com/itm/Ignition-Coil-Honda-CB-400-450-500-550-1965-1966-1967-1968-1969-1970-1971-1972-/251782536707?fits=Model%3ACB400F&hash=item3a9f689e03:g:OMQAAOSwGWNUWjor&vxp=mtr
Offline Garage_guy_chris
Re: mr electrical coils on ebay
« Reply #1 on: January 26, 2016, 10:01:55 PM »
I kept seeing these coils while i was building my bike. I looked into them a few times and from what i found they were typically 2.3 to 3.2 ohms, for points I believe that is too low for points but for an electronic ignition, something like a dyna S they would probably work
    • http://forums.sohc4.net/index.php?PHPSESSID=9fk1v0ae8ac02tjba5ji35n716&/topic,60973.0.html
« Reply #2 on: January 27, 2016, 06:29:42 AM »
they are for newer cb and cbx...used on all Honda s from 1978 an on.. ..my cbx have them..mostly for elektronik ignision systems
« Reply #3 on: January 27, 2016, 05:39:25 PM »
The ad says they work and have a 1 year guarantee on most everything we have plus most twins. It does include later models, and I did recently fry a coil for an electronic bike using it on a points bike. Still wondering, would the ohms be too low for our use?
Offline RevDoc
« Reply #4 on: January 27, 2016, 09:04:14 PM »
Don, why don't you shoot them an e-mail and ask what ohm readings the coils have so you have something definite. If they are around 3 ohm you would want to use Hondaman's 2 ohm resister packs with them.
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
« Reply #5 on: January 27, 2016, 10:47:38 PM »
 I got a single plug version for my 71 cl100 12 volt swap, it checks at 3.8 ohms. I'll ask for an ohm number, thanks.
Update, I sent a message.
« Last Edit: January 27, 2016, 11:05:03 PM by Don R »
Offline Lostboy Steve
« Reply #6 on: January 28, 2016, 06:15:55 AM »
Yes, I found the same data while I was searching.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #7 on: January 28, 2016, 07:25:01 AM »
Thanks for the heads up, 2.42 ohms  plus or minus a few %.  Sorry I didn't listen sooner.
« Last Edit: January 28, 2016, 07:27:35 AM by Don R »
