Author Topic: From Sh*tty to Shiny: Sbeckman7's CB350F Cafe Resto  (Read 64997 times)
Offline MoMo
  • Ride like you're invisible
Re: From Sh*tty to Shiny: Sbeckman7's CB350F Cafe Resto
« Reply #275 on: March 31, 2016, 07:06:45 AM »
^^^^^^I have the entire cylinder. I do not have a press so I'd most likely have to pay someone to remove the sleeves...Larry
« Reply #276 on: March 31, 2016, 07:07:37 AM »
iiAtlas,
I think what you're calling "the head" might be what's called the cylinder 'block' which includes all 4) liners and the outer aluminum part w/ all the fins,correct?
Offline iiAtlas
« Reply #277 on: March 31, 2016, 07:15:14 AM »
Sweet!  From what I've been told, the sleeves drop out if you heat (bake) the block.  No need to press.
iiAtlas,
D'oh! Slip of the tongue, sorry.  Block is what I mean.
Offline MoMo
« Reply #278 on: March 31, 2016, 07:20:35 AM »
I've only replaced sleeves in 2 strokes and every one I ever did had to be pressed.  I would have to have a definite commitment to buy before I take apart the cylinder...Larry
Offline iiAtlas
« Reply #279 on: March 31, 2016, 07:25:49 AM »
Will need sbeckmans thoughts as this is his thread!  What are you thinking on price?
« Last Edit: March 31, 2016, 11:05:47 AM by iiAtlas »
Offline MoMo
« Reply #280 on: March 31, 2016, 06:38:22 PM »
price history on ebay is 75 to 100 for the entire cylinder.  20 a sleeve? ...Larry
Offline iiAtlas
« Reply #281 on: April 01, 2016, 07:39:57 AM »
Larry, that works for me!  I'll still allow sbeckman first dibs as this is his thread.  But if he's okay with it I'll happily take two.  Are you able to mic the I.D. of the sleeves so I can ensure fitment?  I'm looking for ~1.85" (47mm) I.D, the STD bore.  Thanks so much for your help!
Offline MoMo
« Reply #282 on: April 02, 2016, 04:16:23 AM »
Do not have a bore gauge or an inner mike but I do know they are stock as I have the pistons.  There will be enough sleeves for both of you, at least there should be.
Offline sbeckman7
  • Glutton For Punishment And/Or
  • Slow and steady
« Reply #283 on: April 02, 2016, 05:36:40 PM »
Sorry I've been a little out of it lately! I'm going to try an eBay ring set first, and lightly hone the scratched area to see how it feels after.  iiAtlas, if you need some parts from Larry go for it.  I'm gonna hope for the best, and if the sleeves are beyond saving I'll grab some from Larry.
Offline iiAtlas
« Reply #284 on: April 03, 2016, 07:37:26 AM »
Gotcha.  Thanks sbeckman!  I'll snag two sleeves from Larry.  Try not to get too down about your cylinders...I know I did for a bit but you just have to keep trucking!  It'll all be worth it in the end, and the uncertainties are really half the fun :) though maybe not for the wallet  ;)
Larry, please send me a PM so we can proceed!  Thanks.
Offline sbeckman7
  • Slow and steady
« Reply #285 on: April 04, 2016, 04:59:39 PM »
Anyone try the eBay ring sets before?  That's the only alternative to OEM that I see.  Let me know if I missed something!
Offline iiAtlas
« Reply #286 on: April 06, 2016, 05:33:40 AM »
I went down this road a few weeks ago.  Opted OEM and tracked down a set.  They were pricy and hard to find, but so far I'm glad I did.  I can't speak either way about the eBay set.  It could turn out to be a huge money saver and just fine for the quality.  Or, it could lead to your bike constantly pumping oil and giving low compression figures.  I wanted to guarantee my work was worthwhile, so I bit the bullet and went OEM.  IF you can find them, I wouldn't hesitate to purchase.  I had success searching for the part number (13101333010) on Honda dealers websites.  Sometimes they have old stock lying around.  EBay showed a few as well.
This isn't to make you feel either way about either set of rings.  I just wanted to bring you along my thought process and where it got me.  Only time will tell if I made the right choice.  Good luck :) and let me know if you need any help!
Offline sbeckman7
  • Slow and steady
« Reply #287 on: April 07, 2016, 10:47:50 AM »
Waiting to hear back from a small company that may or may not be out of business, but I'm thinking this may work: http://www.retrobikes.com/proddetail.php?prod=100-760&cat=28
If not, I'll contact Hastings Piston Rings and see how much those are, with the eBay set as a backup.
« Reply #288 on: April 07, 2016, 11:04:52 AM »
Hi sbeckman,
Have you tried locating any NOS oem Honda rings ?
Offline iiAtlas
« Reply #289 on: April 07, 2016, 06:16:24 PM »
Good finds!  Interested to see what Hastings has to say.  Could save yourself some $$$ going this route.
Offline iiAtlas
« Reply #290 on: April 10, 2016, 09:33:33 AM »
Sbeckman, MoMo has managed to remove his four cylinders and is sending them my way (thanks Larry!).  I thought it easiest to take all four and distribute later.  Should you find yourself in need of a sleeve or two I've got you covered!
Offline sbeckman7
  • Slow and steady
« Reply #291 on: May 02, 2016, 01:26:01 PM »
Thanks man, I'll let you know.  It's been a while since anything happened over here but sometimes making money is more important than spending it  ;D  I just left a message with the tech at Hastings Pistons to see what they charge for a set for the 350F.  She gets back on Wednesday so I have to wait until then for an answer.  If it's a large amount I'll say f**k it and go the eBay route.  What's the worst that could happen?  ;)
« Last Edit: May 02, 2016, 01:29:36 PM by sbeckman7 »
Offline iiAtlas
« Reply #292 on: May 02, 2016, 01:32:56 PM »
Best of luck!  And thank MoMo - I'm just the "parts bearer"  ;)
« Reply #293 on: May 02, 2016, 01:35:44 PM »
Good to hear you back up on your thread Sbeckman7  :)
Offline Bootsey
« Reply #294 on: May 02, 2016, 04:45:23 PM »
I have no personal experience, but piston & ring kits from cruizin image have been used quite a bit by 750 owners here, as well as  500/550's & other models. From what people have written, they seem like decent quality.
Offline sbeckman7
  • Slow and steady
« Reply #295 on: May 02, 2016, 04:55:58 PM »
That's very comforting to hear!  And it's pretty hard to beat their price too, thanks for the feedback.
Offline sbeckman7
  • Slow and steady
« Reply #296 on: May 03, 2016, 01:29:21 PM »
Last night I decided to just go ahead and order the eBay rings; they should be here in 1-2 weeks.  In the meantime, I'm working on another exhaust option.  The MotoGPWerks Yoshi Replica is no longer an option as I learned after the exhaust was completed that the actual price is $500 and not the $100 listed on the website... That was a real bummer but it gives me the option to take a much quieter route, which I think I'll enjoy after riding the loud Triumph for a few months now.  I know I still want a 4-1 so I'm thinking the MAC header and muffler for the time being, but ultimately I may look at different muffler options.
EDIT: That also means if anyone with a CB400F or 350F wants one of the MotoGPWerks exhausts, there is one currently made and available.  Here is a link to the page (note price is 500 and not 100!!) http://www.motogpwerks.com/shop/exhausts/version-1-4-1-system/honda/cb400f-1974-1976.html
« Last Edit: May 03, 2016, 01:36:15 PM by sbeckman7 »
Offline sbeckman7
  • Slow and steady
« Reply #297 on: May 10, 2016, 03:32:03 PM »
Back in the garage and it feels great  :D   Look what came yesterday:
I began installing them this afternoon when a question popped up.  On the packet it says to instal rings with the marked side facing up (both compression rings have a "T" stamped on them, no "R's" to speak of) so I did that, but the two compression rings themselves are noticeably different.  One is all black and is more "expanded," and the other has a silver coating on the outside and is more closed.  I figured the all black one would be the top ring as it will have the most compression force, explaining why its slightly more open when uninstalled.  Do you guys buy that?
Also, I re-honed the cylinder with the scratches in it.  After a few more passes the scratches are visible but I can't really feel them with my fingernail so I'm going to say it's ok.  Measurement of the new rings after the hone is impressive with 0.3mm end gap!
« Last Edit: May 10, 2016, 03:34:49 PM by sbeckman7 »
« Reply #298 on: May 10, 2016, 05:03:45 PM »
The silver coated one(chrome or other hard coating) is usually the top ring as it gets a bit more wear out front,and the black one w/ more spring to it should go second from the top,it helps to control some oil film plus keep pressure up.
Offline sbeckman7
  • Slow and steady
« Reply #299 on: May 10, 2016, 06:06:55 PM »
Glad I asked :) Thank you grcamna2!
