Author Topic: From Sh*tty to Shiny: Sbeckman7's CB350F Cafe Resto  (Read 65935 times)
Offline sbeckman7
  • Glutton For Punishment And/Or
  • Slow and steady
Re: From Sh*tty to Shiny: Sbeckman7's CB350F Cafe Resto
« Reply #350 on: June 21, 2016, 10:50:04 AM »
S,
You might consider getting 'Timeserts' for the valve cover thread repair job,the kit is pricey but those inserts will last you for a long time  ;)
Thanks for the idea, but the cost doesnt justify it for me.. at least not at this stage  ;D  If it ever starts to leak, I'll look at the timesert.
Loving this work so far! keep up the good work! Just a thought with the rusted fork legs, do you have time/facility to soak them for a couple of days in a bath of white vinegar? this will remove most of the rust and make the remainder quite shiny.
I have the time, yes, but I managed to get pretty much all of the rust off with the wire wheel.  It would have been nice to know earlier though!  Unfortunately the upper portion of the forks that were rusted also have some pitting so the vinegar trick probably wouldn't have made such a difference.
« Reply #351 on: June 21, 2016, 03:30:59 PM »
S,
Heli Coil also makes a one-piece insert which isn't as expensive.The pressure from the valve springs is strong tightening that cover down,if it was mine... just saying,I hate to do a job twice.
Offline iiAtlas
« Reply #352 on: June 21, 2016, 04:37:26 PM »
Nice work Sbeckman!  Glad to see you're back at it.  Hub is looking good!
Offline sbeckman7
  • Slow and steady
« Reply #353 on: June 21, 2016, 06:00:13 PM »
Two steps forward and one step backwards as is becoming the new norm for me.  Got the bottom triple home to paint and pulled apart the rear hub (meaning I pulled the brake cover off).  All is well in there, could probably do with some new pads.  The front hub, however, is absolutely not budging.  No idea how to get enough leverage on that stupid nut... Any ideas?  Is it reverse thread?
The real downside of today was discovering significant rusting on the lower portion of the front shocks, below the chrome covers.  It means I need new forks, and this has left me scouring eBay and there's not a lot available.  I'm assuming I can use CB400F front shocks, and any other models?
« Reply #354 on: June 21, 2016, 06:10:16 PM »
You can also find a good pair of CB360T(33mm) fork tubes and they'll work.
Offline sbeckman7
  • Slow and steady
« Reply #355 on: June 21, 2016, 06:27:19 PM »
Thanks! There's a decent set of 360 forks on eBay, that's just what I needed to know :)
Edit: What about the CL360 forks?
« Last Edit: June 21, 2016, 06:33:23 PM by sbeckman7 »
Offline Denver_Larry
« Reply #356 on: June 21, 2016, 06:47:46 PM »
I've got a set of 350f forks.  Some surface rust on the uppers, not sure about the functional parts.  I'll check and get you some pictures
2005 RC51
1973 CB350F...project
Offline sbeckman7
  • Slow and steady
« Reply #357 on: June 21, 2016, 07:50:13 PM »
Let me know, although I think the uppers will be exposed on my build so depending on rust it might not be worth it
« Reply #358 on: June 21, 2016, 09:12:12 PM »
The CL360 fork tubes are the same 33mm dia. but not certain if they're the same length.
« Reply #359 on: June 21, 2016, 10:11:13 PM »
I'll get a closer look at them tomorrow.  Just had knee surgery so it's a bit of a project getting me out in the garage!
2005 RC51
Offline sbeckman7
  • Slow and steady
« Reply #360 on: June 21, 2016, 11:57:32 PM »
No worries, hope you heal up soon!
« Reply #361 on: June 22, 2016, 12:37:37 PM »
Untouched:
After wiping down with wd40:
The uppers aren't pretty and most likely aren't ever going to be unless you want to cover them up, but the functional part of the tubes are in great shape....
2005 RC51
Offline sbeckman7
  • Slow and steady
« Reply #362 on: June 22, 2016, 04:32:46 PM »
Thanks for the images Larry, I'll try my luck on eBay for as clean of a set as I can find :)
« Reply #363 on: June 22, 2016, 06:20:02 PM »
No worries, I get it!
2005 RC51
Offline sbeckman7
  • Slow and steady
« Reply #364 on: June 23, 2016, 07:28:05 PM »
Slow and steady wins the race... Lower triple is painted and tapered bearings are in for good.  Too bad I forgot the upper at home  ;D
Offline sbeckman7
  • Slow and steady
« Reply #365 on: June 28, 2016, 11:49:16 AM »
Another day, another part on the frame!  The helicoil kit arrived as well so I can start on that when I get back from my little 4th of July vacation, but for now I'm off to enjoy the lake life  8)
« Reply #366 on: June 28, 2016, 12:26:12 PM »
I hope you enjoy
Offline sbeckman7
  • Slow and steady
« Reply #367 on: July 10, 2016, 05:16:04 PM »
I hope you enjoy
Thanks!  Finally got an awesome pair of front forks off eBay.  I was holding out for a nice set because they will be largely exposed on the bike (removing the stock covers and going to use different headlight ears to attach a new light).  Happy the wait paid off  :)
« Reply #368 on: July 10, 2016, 05:21:22 PM »
I hope you enjoy
Those look good.I hope you get her on the road for the Summer.
« Reply #369 on: July 10, 2016, 08:44:54 PM »
They look pretty good on the outside.  You should service them while they are off the bike (new oil, seals and springs).  40 year old springs don't provide the best suspension, assuming that these have not yet been rebuilt.
« Reply #370 on: July 11, 2016, 05:22:11 AM »
+1 service them,new seals and a full disassembly to clean out any gunk that made it's way past the seals at some point.
Offline sbeckman7
  • Slow and steady
« Reply #371 on: July 13, 2018, 03:17:13 PM »
Well it's been more than a little while since my last post. Here's what's happened:
- I graduated Oxford Brookes University in England with a BEng Motorsport Engineering degree
- Moving back to Oxford late August/early September to start a car company and build a tiny electric sports car
- Thoroughly enjoying my time at home and decided to see how much work I can get done on my CB350F before it's time to head back!
I purchased a rebuilt ported head with 400F valves installed but didn't find out until installation time that the threads to the valve cover were all stripped.  So, that's where I left off and where I am now picking up:
Using helicoil inserts for all of them, hope to be done by tonight  :)   Now... what is the best way to paint the entire engine black without taking it apart? Seal up all ports and spray can with engine paint?
« Last Edit: July 13, 2018, 03:39:01 PM by sbeckman7 »
« Reply #372 on: July 13, 2018, 05:02:25 PM »
Lots of cleaning and degreasing. There are any number of small rotary brushes. Just be sure to not leave any inside.
Simple Green or equal, brake cleaner or similar on final cleaning
Lots of careful masking
Duplicolor paint is popular and seems to hold up.
Offline sbeckman7
  • Slow and steady
« Reply #373 on: July 14, 2018, 12:17:09 AM »
Thanks for the cleaning tip! Made more progress tonight but didn't finish up completely; I realized I need to order a few more helicoils than I had originally planned on.  So those are on the way, along with some new o-rings to seal the oil ports.
