Author Topic: Carburettor initial set up after rebuild? (1971 K0 500 Four)  (Read 493 times)
Offline paulbaker1954
  • I 'll just be 5 minutes dear!!
« on: February 02, 2016, 10:12:53 AM »
Anyone any advice on setting carbs up. I am anticipating investing in a balancer but for now have bench set using a small allen key so all 4 are the same. I have also set the mixture screws all at one turn out.
My plan is to get her going first then adjust the mixture screws before balancing but is there a methid of setting the mixture screws up without using a Colortune. There is something in the Honda setup manual that is downloadable from the site but seems there might be a page missing.
Any help/advice most welcome
If you think there's light at the end of the tunnel it's usually another train !!
2014 Triumphy Trophy 1200
1971 Honda CB500 Four K0
Re: Carburettor initial set up after rebuild? (1971 K0 500 Four)
« Reply #1 on: February 02, 2016, 10:19:37 AM »
Assuming all else is in order (all maint items.  jetting is correct for intake and exhaust setup, and a vacuum sync has been done) you can 'tune' each mixture screw setting by looking at plug color for that cylinder.
The goal is a light brown insulator tip.
