Author Topic: CB650 vs CB550 oil pump  (Read 2039 times)
Offline cafe75-550
« on: November 08, 2006, 03:49:46 PM »
Does anyone know what the differences are between the 650 and 550 oil pump? I noticed that in the post on Dr. Tom's hybrid AHRMA 650/550 he's running a 650 oil pump with his 550. Is the output higher? Thanks!
New bike!
'07 Triumph Speed Triple 1050
Never enough projects!
'75 CB550 "Cafe", '76 CB550 parts bike
'64 Norton Atlas featherbed/'71 Triumph 750 Triple (Triton project)
'68 BSA Thunderbolt (frame and cases, project in the wings)
'57 Triumph Thunderbird (frame and mostly complete engine)
Offline cb650
Re: CB650 vs CB550 oil pump
« Reply #1 on: November 09, 2006, 04:49:14 AM »
Dont know but have a couple 650 pumps laying around.
                        Terry
« Reply #2 on: November 09, 2006, 08:10:42 AM »
Not 100% sure but i think the 650 is the same and is what is available now. having said that i do have in my possesion an oil pump that has an extra oil feed sealed with a small "O" ring on the crankcase surface--unfortunately it came in a bag of bits so i have absolutely no idea what its off, it may be 650 as there was a 650 crank and 650 cylinder with pistons with it, both these are now with Ted Hayes for one of his specials! Also the rotors are identical to 500/550
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #3 on: November 09, 2006, 09:21:51 AM »
i'll have to examine them, but i believe they are the same.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline cafe75-550
« Reply #4 on: November 09, 2006, 01:11:36 PM »
Thanks! I have a working 550 pump, was just curious if the 650 had a higher output. If they did then I'd be looking for one, but since the consensus seem to be that they're the same I'll probably just leave it alone....
New bike!
Offline jt
« Reply #5 on: November 09, 2006, 01:17:01 PM »
The 650 pump will bolt up ( have done a test fit) the cover on my 500 engine will not go on completly, you will have to make a cut out on the lower side. If you have a 550 maybe you could use a 650 cover. The 650 pump is wider in it's cross section.
JT
