Author Topic: -Project Suzzie-  (Read 76110 times)
Re: -Project Suzzie-
« Reply #275 on: April 16, 2016, 02:54:00 PM »
Good work as usual TT... ;)
Offline toytuff
  • "watching the pinheads"
« Reply #276 on: April 16, 2016, 02:56:37 PM »
Keep throwing money at it something is bound to happen.  ;D
Thank you Sir.
« Reply #277 on: April 16, 2016, 03:21:50 PM »
Thank you Sir.
Don't i know it... ;)
« Reply #278 on: April 16, 2016, 03:25:53 PM »
Will you be going with the large size tank decal as on the left? or the smaller one per the right ?
I like the smaller size one..
Offline toytuff
« Reply #279 on: April 16, 2016, 03:31:02 PM »
Large. This is why they were redone. Need the smaller?
« Reply #280 on: April 16, 2016, 03:57:47 PM »
I'd love to find a bike just like yours,  :) Then I'd go with the smaller ones !
Offline toytuff
Front fork week.
« Reply #281 on: April 18, 2016, 07:29:03 AM »
Might as well get going on the next project.
Offline toytuff
Yuk!
« Reply #282 on: April 18, 2016, 11:41:25 AM »
And not much oil in them either.
All new parts to go places.
« Reply #283 on: April 18, 2016, 09:41:49 PM »
Christmas parts  :D
Offline toytuff
« Reply #284 on: April 19, 2016, 12:37:24 PM »
Made a left turn and started on other stuff. Trying to find out how to disassemble the forks. We have an air valve and what appears to be a very small ring. No idea how to remove this at this time.
So, let's finish up the headlight, speedo, tach and most importantly new headlight ears with new cushions and trim rings top and bottom. Ah, it's the little things ya know.  ;)
Parts!
Needed the forks installed to line everything up, tightened up the top clamp and done.
I need to skip a day. Been hitting this hard. Fuel tank into body shop, very reputable business. Will see.
Later...
« Last Edit: April 19, 2016, 12:41:45 PM by toytuff »
Offline toytuff
« Reply #285 on: April 19, 2016, 04:56:35 PM »
Just can't stay away!  ;D
Done! Push down with tool and dig the ring out. Took many, many tries I might add.
I don't have the proper seal driver but have heard of an inverted socket with extension to drive it in. Good or bad?
I'm sure my friends shop has one but can't get there until Saturday. Would like to get this done.  ;)
« Reply #286 on: April 19, 2016, 06:04:01 PM »
A piece of PVC pipe.. I have an adjustable fork seal driver that will work;what size are those fork tubes ?
Offline toytuff
« Reply #287 on: April 19, 2016, 07:46:32 PM »
The seal measures 43 mm. No, not using pvc pipe.
Might take the Ducati out for a spin Thursday and run over to Shop in California. I'm sure he has one. I'll send a text tomorrow.
« Reply #288 on: April 19, 2016, 08:07:03 PM »
tt,
I have one you can borrow,send it back when you're done;let me know.
Offline toytuff
« Reply #289 on: April 20, 2016, 01:41:11 PM »
tt,
Dennis said he had one so its a early morning ride on the Duc. Getting hot, damn it. Thank you for the offer.
No time to work on them today. Lower bolts always a pain, might have to impact those off also.
« Reply #290 on: April 20, 2016, 03:45:56 PM »
OK,glad you're guy there has it.  ;)
I always hit them w/ the impact gun very lightly just enough to break them loose but not enough to leak.. before(if possible)I even remove the front wheel,etc. and while the front end is still all together,otherwise it's a real pain to brace the lower part from turning w/o a helper while it's all in a bench vise.Those triple clamps sure help to hold the tubes securely.
Offline toytuff
« Reply #291 on: April 20, 2016, 04:02:00 PM »
Well, I hope it will work. Wierd seal.
Holding things down not a problem.  ;D  Have a 4 inch on the lift table too. Going to throw it in the freezer overnight, get the neighbors 3/8 driver and whack it a couple of times.
The problem is the fact that the bolt its self is recessed so a regular hex socket does not reach. The left is accessible and can be heated.
« Reply #292 on: April 20, 2016, 07:30:45 PM »
So, this is a hex head bolt rather than a hex socket head bolt. Sounds like a good candidate for replacing it with the later might be in order to making service easier.
A good quality socket will be thin wall construction. S&K, Snap-On still make nice thin walled socket if you can obtain one if you don't have one to fit.
« Last Edit: April 20, 2016, 07:33:31 PM by RAF122S »
« Reply #293 on: April 20, 2016, 08:35:05 PM »
tt,
I think you'll need a helper to 'pull' downward on that fork tube below to put pressure up inside the fork assembly to hold-back some resistance on that lower allen bolt(if you remove the bolt like you have that fork oriented w/ the black 'lower' facing upward)while you're using a 1/2" drive power impact gun to give it a few sharp 'bursts' to break the allen head bolt free.They do get frozen sometimes up inside the forks.Those are most likely the same as all the other 80's Suzuki's w/ a recessed female allen head socket bolt(most likely an 8mm threaded bolt)which you'll need a long allen socket to attach to the 1/2" drive power impact gun.I don't think it will be too tough w/ that but may be if you try using a hand impact driver..
Offline toytuff
Huh, say what?
« Reply #294 on: April 21, 2016, 01:25:59 PM »
tt,
I'll finish up right side tomorrow then onto left side.
« Reply #295 on: April 21, 2016, 01:31:56 PM »
That's a nice looking vice you have there in that last pic.  8)
Offline toytuff
« Reply #296 on: April 21, 2016, 01:54:26 PM »
Oh, you mean my overkill locomotive vise? Yeah, couldn't find anything better than what I had so I went to Amazon. Imagine my surprise when this thing arrived!  :o
What the he!! I said. ;D No place to mount this heavy duty piece of iron. Could barley pick it up. I bought some material, a friend welded it up then some left over spray paint on the post.
Yeah, it's a little much alright but boy can I clamp and crush shid now!  :P
« Last Edit: April 21, 2016, 01:56:47 PM by toytuff »
« Reply #297 on: April 21, 2016, 02:47:21 PM »
I noticed that too!  I'd like to move mine off the workbench but it's nice to have it mounted to a solid surface.
tt - could yours tip over on that stand?
Offline toytuff
« Reply #298 on: April 21, 2016, 03:16:51 PM »
Yes, yes it will. I can bend small stuff, hold stuff, crush stuff but any large work is a no go without a solid mount. Someday I'll have a strong steel bench welded up but for now a 4 inch vise is mounted to the lift table.
Yeah, it's a big boy. 6 inch wide jaws. Made by Yost.
Works great for fork work and locomotive repair.  ;D
« Last Edit: April 21, 2016, 03:29:27 PM by toytuff »
Offline toytuff
« Reply #299 on: April 21, 2016, 03:20:58 PM »
Crushed this the other day.
