Author Topic: CB750: Aware of cheap parts -tensioner rubber cracked in 2- Carb boots cracking  (Read 53704 times)
Online grcamna2
Just ordered their engine seal kit today. Will stay away from their other parts.
Thinking about making a primary tensioner roller from Delrin, how would you think it would hold up?
I have one on a CB350 twin and it's holding up well.
First off I'm not at all questioning your abilities, but herein lies the problem. How do you know it's holding up well? Maybe you had it apart to check, don't know. On my racebike I had to make a drive chain guide because of the swingarm angle and tried different materials. Delrin lasts one season. Maybe an internal roller with lots of lubrication will survive better, but it's just not easy to check.
I have had the engine apart twice in 5K miles and the PA6 material(which is used for timing gears in certain automobile applications)is holding up well w/ no extra wear,I didn't take any pics but it looks good:CB750 and CB350 twins use the same rollers.
grcamna2, how did you mount the top wheel in the tensioner? Is it a rivet supplied with the kit? Or do you need to reuse the old from the Honda tensioner?
This is disconcerting  :-\
My 750 is running really well.  Just completed my after winter tuneup to get ready for riding season  >:(
Online grcamna2
The man who sold me the original PA6 rollers  is on hondatwins.net his name is Pawel and he's from Poland.He supplied the rollers w/ 3) types of rivets: one was soft aluminum,the other a mild steel and the last one a bit harder steel,I used the harder steel one and did carefully rivet that one according to the directions(in english)that he supplied me with in the roller kit.He also sells the rollers on Ebay(seller name 'Pawelzak') when he chooses to but has his own website too.
He has stopped using the PA6 material for some reason and is now using steel similar to the roller kit you posted which i've quoted in your thread here.The parts look very similar from both suppliers in the pics you posted but I've never owned a set of steel rollers yet. The steel roller kits sure do look like quality parts and Pawel mentioned in hondatwins.net that he originally fashioned them from the same design as the Italian made Cappelini racing sprockets.
Pawel sent me a PM over on hondatwins.net today after my inquiry to the question I asked if he had sold any to CB750 customers and he told me yes and that he thinks it's the same size roller from CB750K0-CB750F1
« Last Edit: February 15, 2016, 02:34:11 PM by grcamna2 »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
I am feeling your pain. Mine had only 1700 miles and was showing signs of eminent failure.   :(  >:(  :P
New Honda parts will be here tomorrow. A top end gasket kit from 4into1 and I'll have about a two week turnaround on the repair.
Maybe a little longer if I decide to go with the CI 836 kit (highly likely)...  ;)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Might be more for me....A frame kit is looking really good right about now  :-\
The CNC'd tensioner set posted earlier is only slightly less than the CycleX race tensioner.
Member Bill Benton had less than ideal results with the CycleX tensioner when run hard under strictly drag racing conditions...
TAMTF...
Wilbur
Projects:
Steel tensioner is the way except for Honda std that works but become hard after a few  years.
Steel should work  year after year?
Good info. thanks.
I have seen photos of stripped white tensioners. Maybe the High performance forum
The metal tensioner was out of stock 30 minutes ago.  Seller updated stock with more after I sent a question.
I could not resist to order. No rubber pieces in oil pump mesh with this.
http://www.ebay.com/itm/Honda-CB250-CB350-CL350-SL350-CB750-Cam-Chain-Tensioner-Roller-Wheel-Set-/231576401099
Online grcamna2
PeWe,
The seller named Ryan said he is the manufacturer;he also put a google link into my ebay messages w/ instructions on installing the rivet for the top roller/'sprocket' and should also send one to you if you ask.I'm not sure how to paste the message from ebay into the forum here..
I could also try to see his operation personally because he is located not far from my location.
Online grcamna2
The PA6 material is also white
PeWe,
Like this?
https://drive.google.com/file/d/0B31LrzzamA7UbHBFY1E2a2JnMFU/view
So who all will be taking their hammer to the rivet since you don't have a hydraulic press?
:o
If a press is a must I guess I can find one at my job's lab.
Online grcamna2
I think the job can be Carefully & patiently performed w/ a helper and a cast iron 'flat' machined surface if you were out somewhere and had no access to a press,but I would want to use a press.I see just a very small 'flare' to the rivet which is just enough to hold the rivet tightly in the correct aligned position.That part about the oil hole..,since there's no pressure feed that hole must be there all the way through the rivet into the machined/keyed bearing shaft that the needle bearing rides on so the oil can flow/run back out through the center of the machined shaft.I'm not sure where you'd be able to purchase one of those oem Honda machined upper roller shafts as there is no separate part# for it.. but if you were to machine one from scratch it may be a good idea to have the locating 'keys' so it will keep from spinning around the rivet area.
« Last Edit: February 15, 2016, 02:37:05 PM by grcamna2 »
PeWe:
What kind of tensioner do you have? Is it the spring-force tensioner (OEM type) or is it the screw-in pushbar type that must be manually adjusted?
You could do it in a vise if you are careful... ;)
PeWe:
Mark, it is the OEM push bar with a spring.
The metal wheels to be installed in an old tensioner might be the final solution without rubber. I had plannned Honda OEM with rubbers, the metal wheels might be better. The racing guys use similar solution in the racing forum.
Next rubber stuff is the primary chain tensioner... I have a new OEM rubber to be installed unless I get something better within a month that does not cost a fortune...
//Per
PeWe:
//Per
Thanks, PeWe: I do know of at least one incident where someone who used the "manual screw" type of pushbar overtightened his chain and broke the same roller. I don't know what "brand" of roller his (chopper) 750 had in it, though.
I'm looking for a possible "cause" here, in case it is not the materials themselves? I remember from the racing days that guys who increased the tension on the chains (by various methods) also failed the tensioner rollers, chunking out pieces of rubber in the process. This was one of the Achilles' Heels of the Daytona bikes (circa 1970) as they were run at (or above) our max RPM for the whole race: they chunked out the rollers from the 'standing wave" that tends to develop when the cam is bowed downward (in the middle) at constant high RPM (10k RPM or more) and making very high drag loads in the cam bearings, creating some slack in the back side of the chain. This then vibrated somewhat, and this battered the roller material, denting, slipping, and bouncing the upper roller on the arm: this in turn reduced the oil in the chain and upper roller, which caused drag in the roller and wear in the chain, wearing both parts. When a "fix" of a metal roller was introduced on some of those bikes (and often, after Daytona), it accidentally improved the oil retention in the chain because the heavier roller resists the chattering motion (heavier inertia) that flicked the oil out of the chain as it rolled over it. This, of course, improved the chain life, which helped the roller life, etc...
It is also interesting to note that the early bikes (before the New Factory K1 appeared) had MUCH tighter clearance in the 2 inner rocker tower bearings. The cams that appeared from this change had typically 0.002" more clearance in the inner 2 bearings (up to 0.0060" brand new), by reducing the cam OD on those inner surfaces (the rocker towers stayed the same). It appears that Honda's engineers surmised that letting the cam flex downward at high RPM did several good things, like less bearing drag loads and reduced tension on the rollers at constant high RPM - like touring on US Interstates, where we can ride all day at 80+ MPH speeds with nothing more than fuel stops (and I have, as long as 16 hours straight, many times!). When the K1 became the K2, the bikes were MUCH quieter, especially reduced cam chain noise, from this change. My K1 was always chain-noisy inside, while my K2 was immediately not so, for example. I also immediately noticed the K2 power did not fade when hot, as did the K1, and I am sure the lesser cam drag has some effect, here.
The steel rollers (and nylon versions) have persisted for racing applications ever since the 1970 Daytona win. Over the years, there have been many vendors of the rubber roller kits (because Honda starts and stops their supply of them): I just ordered some of Honda's tensioner parts to compare with the "Made in Taiwan" kit I have (unused) in my shop. I'll post here the differences I find, if any, when the Honda parts arrive (2/24 scheduled). The Taiwan parts I have seem to be a 60-ish durometer rubber material. I'll see how that compares with the OEM parts.
I think you will find the Taiwan parts to be very soft when compared to Honda parts. My Honda replacement parts should arrive tomorrow. The only durometer I have is a thumb and forefinger...  ;)
TAMTF...
Wilbur
Projects:
Online grcamna2
Those Taiwan rollers must have been made from some inferior grade of rubber/junk.
Just received a response from Vintage CB750. They have pulled the product from their website and have put the manufacturer on notice until they can get to the bottom of it. They requested photos, so I sent the ones I posted earlier in this thread along with an offer to return the defective parts to them if they need them.
If you can produce a receipt or order number there's a chance that you might get a refund.
When I reached out to them I made it clear that failure of this component could potentially lead to engine seizure and rider injury or death. They seem to be taking it pretty seriously.
TAMTF...
Wilbur
Projects:
