Author Topic: Can't find engine vin? CB750  (Read 3716 times)
Offline ChopSticks
« on: February 07, 2016, 03:04:06 PM »
Alright so I bought a non running 1974 CB750 last year, at time of purchased I was able to match the frame with the title, but I couldn't find the engine VIN for the life of me. Recently I took off the carb and air box and finally found the VIN CB750E-3113834 but I can't match it up at all from the serial directory link below. The frame does match though. any ideas?
http://www.sohc4.net/cb750k-serial-numbers/
Offline MoMo
  • Ride like you're invisible
Re: Can't find engine vin? CB750
« Reply #1 on: February 07, 2016, 03:07:56 PM »
Offline ChopSticks
« Reply #2 on: February 07, 2016, 03:11:35 PM »
based on that it looks like a '78 F3? how screwed am I if I've been ordering parts for a K4?
Offline MoMo
« Reply #3 on: February 07, 2016, 03:17:55 PM »
Depends on what parts you've ordered.  One question, does the rear wheel sprocket line up with the front?  I assume it is a non-runner?
Offline ChopSticks
« Reply #4 on: February 07, 2016, 03:26:17 PM »
Just ordered new carb and air filter boots and a whole alloyboltz allen socket bolt set
well the PO bought it running, then it stopped then I got it. and after a couple weeks I got it to run again but wasn't perfect. idle was everywhere and choppy that's when I found the crap boots that I am just not replacing
Offline MoMo
« Reply #5 on: February 07, 2016, 03:31:03 PM »
Which carbs are on the bike?  newer K7/8 style or older non-accelerator version?  boots could be different
Offline ChopSticks
« Reply #6 on: February 07, 2016, 03:38:16 PM »
http://www.cb750carbs.com/details.html
Based on this reference, I def have a earlier K carb, do I need the F carbs for it to run properly?
« Reply #7 on: February 07, 2016, 06:41:14 PM »
  Roundtop or coffin top carbs?
Offline ChopSticks
« Reply #8 on: February 07, 2016, 06:58:03 PM »
No idea what coffin top is but they're exactly the same as the k1-k6 in that link with the rubber dust top thingies
« Reply #9 on: February 07, 2016, 07:16:36 PM »
absolutely not, and imo, the roundtops are just plain better.  I have had roundtops on my F3 for about 8000 miles now.
Offline ChopSticks
« Reply #10 on: February 07, 2016, 07:23:11 PM »
Whew  :'( do you know if the boots that I ordered for the k4 will fit? Also anything else I need to be aware of from the differences?
« Reply #11 on: February 07, 2016, 07:33:52 PM »
the boots should fit, although they might be a tight squeeze...lots of lube and a little heat from heat gun will really help.  The boots I use are old and stretched out.  What year is your frame and tank?  You should post some pics.  Its hard for me to think of all the changes required because I have spares from all years that I can just grab and make stuff work.
Offline ChopSticks
« Reply #12 on: February 07, 2016, 08:11:41 PM »
My frame is a k4 and the tank looks from that era also it's orange specle.. I'm not home night now but I'll post once I get home..  What changed on the boots? I might still be able to cancel the order since they had to order them, but the site doesn't have the F boots available
« Last Edit: February 07, 2016, 08:15:45 PM by ChopSticks »
« Reply #13 on: February 07, 2016, 08:22:02 PM »
Boots, does the head have 410 on top fin intake side? If so the intake fitting is larger.
Offline ChopSticks
« Reply #14 on: February 07, 2016, 08:24:35 PM »
Any pic reference? I can check right now
« Reply #15 on: February 07, 2016, 08:31:30 PM »
77'/78' both f and k carb boots are a totally different shape than earlier boots for roundtops.  F2/3 (77/78) boots will not work for you anyway unless you have the coffin top/Keihin PD41 carbs.  What I can't remember right now is if the F3 intake spigot is bigger diameter than K0-K6...whether it is or not the K0-K6 boots can be made to fit.  I have them on my F3.
Oops, I see Jerry has answered this question...what you can do is grind the inside diameter of your K0-K6 boots enough for them to fit the larger spigots.  That must have been done to mine by a previous owner.
Offline ChopSticks
« Reply #16 on: February 07, 2016, 08:41:54 PM »
I guess what's better, to keep my k0-k6 carbs and try to fit the k0/k6 boots? or look for a set of correct carbs and correct boots?
If the better choice is the former, would I need to get different jets or set the needles different to properly tune with the F engine?
« Reply #17 on: February 07, 2016, 09:14:27 PM »
I really don't think it will be very hard to fit the k0-k6 boots...as said before, I think the f3 carbs are overly complex with accelerator pumps and a really messed up choke mechanism and suck anyway and new boots for them are rare and expensive.
     I dont know what my needle position is, but I run 115 mains, 40 idles, air screws 7/8 out...k&n filter in the stock airbox and a Jardine 4 into 1 with a loud megaphone
« Reply #18 on: February 07, 2016, 11:36:34 PM »
 Does your exhaust have two bolts or nuts holding pipe on or just a clamp with bolt underneath ?
Offline ChopSticks
« Reply #19 on: February 08, 2016, 05:58:15 AM »
uploading for ref will reply once I get to work
Offline ChopSticks
« Reply #20 on: February 08, 2016, 10:37:45 AM »
Alright I think I'll just keep the same set up and the new boots will somehow fit, since it's probably the cheaper route instead of trying to find a whole new rack of carbs. I just initially thought the engine needed a specific set for it to run properly
Not exactly sure about the exhaust the pic I uploaded above is the best I got they currently have 2 2into1 exhausts. Could you give me a pic reference for the two bolts or nuts or clamp set up? Since I live in an apt the bike is readily available until days I work on it, so just wanna make sure I know exactly what to look for
I tried googling the 410 stamp but couldn't find it anywhere so if someone has a pic of that would be great
« Reply #21 on: February 08, 2016, 10:51:06 AM »
Bottom right of photo, just below the cam chain tunnel.
Your pistons will also be stamped 401 near the wrist pin hole
« Last Edit: February 08, 2016, 10:59:56 AM by flybox1 »
"This is my CB. There are many like it, but this one is mineā€¦"
« Reply #22 on: February 08, 2016, 11:09:58 AM »
 At the head/header connection it uses two studs and nuts tightening a finned flange OR  there's a flange with countersunk phillips type bolts on the engine then the finned pipe flanges clamp over it with a single pinch bolt. The latter is early style.
  Some headers use no finned flange, just plates on the pipe and studs/nuts.
« Reply #23 on: February 08, 2016, 01:59:38 PM »
...not sure why you would worry about the exhaust clamps, as either style can be used on any cb750 engine...
« Reply #24 on: February 08, 2016, 02:57:10 PM »
 the reason i asked about exhaust , is to answer how screwed am i, if i order parts for a K4...
sucks to order an exhaust new the find out you have to source whole new mounting hardware..
