Thanks flybox. I used a bit of heat to assist the jammed valve. Apparently a bit too much as the nylon square melted a bit and popped out. I was able to press the square back in but now it won't hold prime. I can spray fuel out of it with the pump but as I release the pump rod it sucks fuel back to the bowl through the check valve.
