Author Topic: I need a float bowl  (Read 631 times)
Offline cuz
I need a float bowl
« on: February 08, 2016, 06:33:55 PM »
I have a malfunctioning check valve for the accelerator pump in the number 2 float bowl of my cb750k7.   Does anyone have a bowl with a functional check valve complete with drain screw they would sell?
« Last Edit: February 08, 2016, 07:13:14 PM by cuz »
Offline Gman
Re: I need a float bowl
« Reply #1 on: February 09, 2016, 05:05:23 AM »
Check with member harisluv on the forum.  He's the go-to guy for all things carb related.
You can find him in the service section for carb rebuilding.
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
« Reply #2 on: February 09, 2016, 07:16:57 AM »
ultrasonic cleaner with purple simple green works great to clear this.
Offline cuz
« Reply #3 on: February 09, 2016, 08:21:07 AM »
Thanks flybox.  I used a bit of heat to assist the jammed valve.  Apparently a bit too much as the nylon square melted a bit and popped out.  I was able to press the square back in but now it won't hold prime.  I can spray fuel out of it with the pump but as I release the pump rod it sucks fuel back to the bowl through the check valve.
« Reply #4 on: February 09, 2016, 09:08:26 AM »
sounds like you got one of the earlier bowls with the plastic plug.
the latter ones came with brass plugs.
harisuluv is your best bet at a replacement bowl.
