SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
Project Shop
Topic:
Oil pump stopper valve
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Oil pump stopper valve (Read 1707 times)
mrbreeze
Not your average
Really Old Timer ...
Shut up when you're talkin' to me!!
on:
February 09, 2016, 03:38:52 PM »
I'm changing out my stopper valve seal with Elan's kit and have a question. Which side of the valve does the stopper seal sit in? The valve has a large and a small diameter but the seal fits in either side. The pictures in my shop manual and the Chiltons don't show this difference. Does the seal live in the smaller diameter side and the spring in the larger side or vice-versa? My bad for not paying closer attention on disassembly but you would think it would be noted in the pictures in the manuals.
Logged
MEMBER # 257
edwardmorris
Youngish
Old Timer
Do not cause harm, nor respond to harm with harm.
Re: Oil pump stopper valve
Reply #1 on:
February 09, 2016, 03:43:27 PM »
I wish I remembered, but I found a pic from my disassembly, not sure if you can tell the diff here either. IIRC, when I put it back together, things only fit one way.
Logged
72 CB750 - Rebuilt to NEW OLD STOCK
BOTM August 2015
BOTY 2015
73 CB750 - Project Terry's Fault
Braided Stainless Steel Oil Lines CB750
Don't meet your heroes, stay clear of the Open Forums.
mrbreeze
Not your average
Reply #2 on:
February 09, 2016, 03:53:42 PM »
I can't really tell from your picture. It looks like the valve is covered in sludge. The pictures in the book don't show the 2 different diameters of the valve. I want to make sure I have this thing in the right position.
Everything looked great.........no metal in oil. There was a small amount of crap in the bottom of pan that is probably 40 years of clutch lining but that should be normal. The only reason for installing the kit is to have higher oil pressure when warmed up. I've read that some bikes hold closer to 60 psi at an idle after full warm up. Mine's around 20.
Logged
MEMBER # 257
mrbreeze
Not your average
Reply #3 on:
February 09, 2016, 09:20:01 PM »
After abandoning the search function here....I googled Honda 750 oil pump stopper valve and went to images. Several pictures showed the smaller diameter going in first with the stopper seal inserted there. The larger diameter is towards the outside where the spring sits.
This leaves me with 2 questions.
1. Why doesn't the shop manual or the Chiltons show this detail?
2. What happens if it's installed backwards?
Logged
MEMBER # 257
grcamna2
Not a
I love to restore & travel. Keep'em Going Strong !
Reply #4 on:
February 09, 2016, 09:44:47 PM »
bump
Logged
edwardmorris
Youngish
Old Timer
Reply #5 on:
February 09, 2016, 11:19:35 PM »
OK, I was able to confirm it. I no longer have an extra oil pump (traded for a spark advancer) but I do have the BOTY Franken-O'Digger trophy
Opened it up and that's how it is. Also, instead of looking there in the first place, I remembered Mark's book at the very end. Pix in there show it to be the same way.
Logged
BOTM August 2015
BOTY 2015
mashfu
Enthusiast
Reply #6 on:
February 10, 2016, 12:55:25 AM »
Just rebuilt the pump tonight too. Just like in Rafi's photo, stopper was on small end leaving larger for the spring
Logged
mrbreeze
Not your average
Reply #7 on:
February 10, 2016, 02:15:51 AM »
Hey guys...thanks for looking. At least now if someone does a search on this subject they will run into this post. I still wonder what would it would do if installed backwards although I'm not gonna try it. I'm not "that" curious!!
Logged
MEMBER # 257
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Project Shop
Topic:
