Author Topic: Need to confirm wheel spacer length CB 750  (Read 933 times)
« on: February 09, 2016, 06:55:22 PM »
The wider part of spacer measures approx .68 long, i think correct for 1975 F
 I am assuming 77 78 are longer ? Not sure how long.....
Offline enwri
  • So that noise is normal?
Re: Need to confirm wheel spacer length CB 750
« Reply #1 on: February 10, 2016, 11:40:32 AM »
this any help? 77k, and earlier spacers. in mm
may not be on the right axles, mixed up.
« Last Edit: February 10, 2016, 11:43:32 AM by enwri »
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
« Reply #2 on: February 10, 2016, 10:41:17 PM »
The one in the middle of the lower 77 axle, do you know if it came off 77/78 ?
Can you measure the length of the thicker portion if you get a chance.....
Offline enwri
« Reply #3 on: February 11, 2016, 01:57:37 AM »
middle lower is a 750 77k, 42mm overall,  the larger part is 26mm.
from the taller carrier.
« Last Edit: February 11, 2016, 02:03:03 AM by enwri »
8? XJ 550 meh...
