Author Topic: Ignition issues.  (Read 5117 times)
Offline Sdsbassist
  • Gus, Austin, MN.
Ignition issues.
« on: February 13, 2016, 05:28:44 PM »
Cb750 ignition. POwner can't find key. No number on face, but number WC21B. What is this? More strange twists.
Sent from my SM-N900V using Tapatalk
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Re: Ignition issues.
« Reply #1 on: February 13, 2016, 07:01:09 PM »
The mounting tab is an old Rocky Cycle (et al) on-the handlebar mount for these switches. Besides that, the connector on the wires would tell you if it was for a 750K0-K2 (early) or a K2 (late) to K6 type. Or, if it is a CB/CL350 type, being sold by EMGO as CB750, which melts itself apart when used...the key number is not Honda unless it came from their seat-steering-ignition key set ("671" parts kit).
Offline Mantree
« Reply #2 on: February 13, 2016, 08:33:43 PM »
If you don't have locking gas cap and the fork lock or seat lock I have a ignition with keys that came off my bike when it got custom rewired
Sent from my ME302KL using Tapatalk
« Reply #3 on: February 13, 2016, 10:12:39 PM »
I think that's an aftermarket switch to your bike,Honda would certainly have a different(like #T....)number.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #4 on: February 14, 2016, 08:39:16 AM »
Looks like this will be the route...can you shoot me a pm?
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #5 on: February 14, 2016, 09:03:24 AM »
I pmd you first
Gus, Austin, MN.
Offline Mantree
« Reply #6 on: February 14, 2016, 09:23:29 PM »
Sent from my SM-G900V using Tapatalk
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #7 on: February 15, 2016, 05:29:26 AM »
Only difference is that I have a round plug. Easily splicable! Thanks a ton!
Gus, Austin, MN.
« Reply #8 on: February 16, 2016, 04:07:07 PM »
If you use this switch, I suggest also adding a relay that is switched by the BLACK wire, to take the power off the switch. These are the EMGO knockoff units with light wires and small contacts, made for the CB/CL350 bikes. On the Fours, it eventually melts the wires off the back of the switch. :(
I have one on my 750, now 4 years, but added a relay to solve this problem.  ;)
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #9 on: February 16, 2016, 04:18:38 PM »
Can to show me an example of this? It's already on the way I think. I'll be splicing anyways so now is a good time for a relay
Gus, Austin, MN.
Offline Mantree
« Reply #10 on: February 16, 2016, 06:29:28 PM »
That is actually a good suggestion I use relays to take the load off of all my switches
http://www.rattlebars.com/mtz/basicrelay.jpg
This is a relay what you want to do is suply power to the hot pin from the battery then out to the fuse box on the wire that you cut to coming from the switch then run the wire switch side to one of the triggers and ground the other that way the switch is just turning on the relay and the relay is handling the load.
Offline Airborne 82nd
« Reply #11 on: February 16, 2016, 10:41:58 PM »
http://sohc4shop.com/catalog/product_info.php?cPath=23&products_id=49
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #12 on: February 17, 2016, 04:10:49 AM »
I'll see what switch I get and go from there. Thanks guys
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #13 on: February 20, 2016, 06:46:01 PM »
Couldn't I solder my old stuff to the new switch?
Gus, Austin, MN.
Offline calj737
  • I refuse...
« Reply #14 on: February 21, 2016, 05:40:05 AM »
Why not simply swap the plug end from your stock unit to the new unit?
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #15 on: February 21, 2016, 05:40:39 AM »
Sounds like the wires are smaller on the new.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #16 on: February 21, 2016, 10:19:35 AM »
Successful splice :)
Gus, Austin, MN.
« Reply #17 on: February 21, 2016, 12:33:04 PM »
Why not simply buy the correct switch?
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #18 on: February 21, 2016, 12:35:53 PM »
Steve o...youre really raining on my parade today! :)
Gus, Austin, MN.
« Reply #19 on: February 21, 2016, 02:18:41 PM »
Your parade need a better organizer!
« Reply #20 on: February 21, 2016, 03:12:01 PM »
Click on Hondamans name, then his web site for the relays.
Offline oldhatt45
« Reply #21 on: February 22, 2016, 05:14:57 AM »
Sdsbassist,
Here is a wiring diagram for the750 K6 (1976).
I made this diagram up when I was wiring my K6.
Hope this helps,
Charlie
« Reply #22 on: February 22, 2016, 05:21:03 PM »
Look at reply #11 :) :)
« Reply #23 on: February 22, 2016, 05:30:14 PM »
oops. at least we agree.
« Reply #24 on: February 23, 2016, 07:21:08 PM »
Yup!
