Author Topic: Bimota HB1 Clone build  (Read 69215 times)
Re: Bimota HB1 Clone build
« Reply #100 on: April 02, 2016, 03:07:12 PM »
Very nice, can't wait to see the frame... ;)
Thanks for the link in the Brembo thread about the Airtech oil tank inner fender. I saw that and am considering it. Let say it is on the table.
Rob
No problem... ;)
Offline Artracing
« Reply #101 on: April 02, 2016, 04:10:14 PM »
Needle bearings in swing arm.
Offline Artracing
« Reply #102 on: April 02, 2016, 04:25:44 PM »
Made a few iconic swing arm frame mounts.  No fun machining 4130. These are the pieces built into the frame as sort of a socket for swing arm to fit into. The swing arm uses two bolts instead of one long axle. The bolt is custom, like a shoulder bolt with disc on the end with holes to match the frame mount. The  cluster of holes in the frame mounts are threaded. The bolt disc fits into the socket and then screwed in. You then attach the nut on the inside to secure the swing arm
It is quite the elaborate design. I have no idea why it was done this way.
Much better way to do it, but this build is all about cloning.
I guess that commits you to building the correct oil tank, Eh!
HAHA, I have to brush up on castings 101 first.
Actually, the proto type HB1 didn't have the front oil tank. He actually put the tank at the  rear of engine under the swing arm in pivot in front of the rear wheel. That is something I have pondered.
Still I'm thinking stealth inner fender oil tank. There is one on this forum that is exactly what I was thinking.
Offline Artracing
« Reply #103 on: April 04, 2016, 06:54:57 PM »
Knocked out a pair of mounts for rear sets. Out of respect, I'm using  Italian made Tarozzi rear set.
Offline Artracing
« Reply #104 on: April 11, 2016, 04:40:21 AM »
Here is photo of real HB1 frame.
« Reply #105 on: April 11, 2016, 02:55:38 PM »
The only thing I don't like about the HB1 frame is, the rear tube coming from the swingarm pivot up to the rear shock mount, I would bring that forward so I could run a more modern shock angle..
Offline Artracing
« Reply #106 on: April 16, 2016, 10:14:19 AM »
Rear Brembo caliper  hanger complete
Offline slikwilli420
  • Master of Disaster
« Reply #107 on: April 16, 2016, 01:41:32 PM »
Looking very tidy. Well done.
« Reply #108 on: April 16, 2016, 03:20:11 PM »
Offline Artracing
« Reply #109 on: April 16, 2016, 04:37:34 PM »
Engine complete.  Nothing special. Megacycle cam and electronic ignition.
« Reply #110 on: April 16, 2016, 09:27:34 PM »
The motor looks very tidy and I like that rear caliper hanger!
Offline Artracing
« Reply #111 on: April 17, 2016, 10:59:10 AM »
Thank you. I hope it runs. The hanger is simple but functional.
Offline simon#42
  • liverpool
« Reply #112 on: April 21, 2016, 01:08:02 PM »
some nice work going on here .
Offline Artracing
« Reply #113 on: June 27, 2016, 07:19:19 PM »
I'm back. It's been busy.
Frame to be completed next week.
Here some eye candy
« Reply #114 on: June 27, 2016, 07:45:30 PM »
Looking good Art... ;)  If you need someone to test it.... ;D ;)
« Reply #115 on: June 27, 2016, 08:44:03 PM »
Art,
The frame is coming along nicely.  Enjoying following this build.
Offline Artracing
« Reply #116 on: July 07, 2016, 02:38:03 AM »
Now the fun starts
Offline calj737
  • I refuse...
« Reply #117 on: July 07, 2016, 03:24:28 AM »
Curious if you have a weight of the frame, and the swing arm?
Offline Artracing
« Reply #118 on: July 07, 2016, 03:35:47 AM »
Something I need to work on.
It's heavy 36lbs
Offline calj737
  • I refuse...
« Reply #119 on: July 07, 2016, 03:56:44 AM »
May I ask, what tubing spec did you use for the frame and for the swing arm? Curious as to there the weight came from is why I ask-
« Reply #120 on: July 07, 2016, 02:06:16 PM »
The frame looks pretty good.  If you used chrome-moly, I'm surprised it's not lighter.
Offline Artracing
« Reply #121 on: July 07, 2016, 03:17:11 PM »
Chromo Moly
Most of the weight is in the swing arm. Need to
Trim the fat
« Reply #122 on: July 07, 2016, 04:22:23 PM »
Chromo Moly
Trim the fat
Is the swingarm mild steel?
Offline Artracing
« Reply #123 on: July 07, 2016, 04:33:11 PM »
It's all moly.
« Reply #124 on: July 07, 2016, 10:17:26 PM »
I suspect may still be lighter than stock.
 What really matters. Is what are you gaining, and in that respect, even heavier (or more reliable ), is still worth it..
