Author Topic: CB750F1 'o' rings.  (Read 565 times)
Offline Skoti
CB750F1 'o' rings.
« on: February 21, 2016, 10:30:33 AM »
Hi,
I managed to buy a new old stock genuine Honda CB750F1 top gasket set (part no 06110-393-S00).
It has only two rubber 'o' rings for the oil feed to the cylinder head. (part no 91310-426-000) 11x2.5mm.
When I dismantled the motor it had two fitted with the cylinder base gasket and two fitted with the cylinder head gasket.
My question is have Honda deleted the requirement for other two 'o' rings from the cylinder base gasket or  the cylinder head gasket?
Not sure where to fit the two supplied 'o' rings!
regards
Skoti.
Motorcycling is life, anything B4 or after is just waiting.
Honda CB750F1 1976
BMW R1150RT 2002
Norton Commando 850 Roadster 1974
Jawa 350 Blue Style 1992
Offline Davez134
Re: CB750F1 'o' rings.
« Reply #1 on: February 21, 2016, 01:23:35 PM »
I'm not an expert on the changes made to the F bikes, but oil flows through those holes and both should have an o-ring. You can find 2 more at a hardware store that are the correct size. Just make sure they are the thickness that honda calls for (can't remember what it is off hand) as they need to "squish" a certain amount to prevent leaking. (Ask how I know
Offline Skoti
« Reply #2 on: February 22, 2016, 02:28:49 AM »
bump.
Honda CB750F1 1976
BMW R1150RT 2002
« Reply #3 on: February 22, 2016, 03:58:13 AM »
As Davez said, you need o-rings there.  Check it against the parts list:
http://www.cmsnl.com/honda-cb750f1-super-sport-1976-european-direct-sales_model14681/partslist/
to find the size you need and than you can buy it locally.  The kit is likely not complete.
