Author Topic: 550F muffler seal?  (Read 394 times)
Offline jonda500
550F muffler seal?
« on: February 21, 2016, 03:05:01 PM »
This muffler gasket has no separate part number. It is a little damaged now - (err because) I tried to take it out but fear I will totally wreck it- is there anything anyone has found that can be used to replace this with?
When I stick in the largest diameter pipe that will go in there and tighten the clamp, the pipe can still rotate - as the muffler is rather heavy, I feel it should be clamped tight to the 4 into 1!
The end of my (modified) 4 into 1 looks like it may fit into the muffler if I removed the packing and just used a little high temp silicone instead, but I don't want to destroy the gasket while removing it only to then find that it doesn't fit!
John
A starter clutch thread:
Offline jonda500
Re: 550F muffler seal?
« Reply #1 on: February 21, 2016, 03:09:39 PM »
Offline Scott S
« Reply #2 on: February 21, 2016, 04:02:24 PM »
 The muffler won't rotate....And is supported...when it's clamped on back at the rear hanger.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
