Author Topic: Chain and sprocket  (Read 680 times)
Offline Sdsbassist
  • Gus, Austin, MN.
Chain and sprocket
« on: February 25, 2016, 02:09:10 PM »
Anyone try a kit?
http://pages.ebay.com/motors/link/?nav=item.view&id=131515375170&alt=web
Sent from my SM-N900V using Tapatalk
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Re: Chain and sprocket
« Reply #1 on: February 25, 2016, 02:17:29 PM »
Ive learned not to trust off-brands.
Stick with Sunstart or JTSprockets, and a known good chain (DID, EK, RK, Diamond, etc...)
Just dont know enough about longevity/wear/strength of those to be confident.
« Last Edit: February 25, 2016, 02:21:09 PM by flybox1 »
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #2 on: February 25, 2016, 05:06:37 PM »
I pulled mine and while dirty aren't stretched and sprockets appear in good shape. Is there a good way to tell if a chain is dead
Gus, Austin, MN.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #3 on: February 25, 2016, 05:38:32 PM »
Test: Setup: On the centerstand, push up on the bottom row of chain, dead center. If the old chain on old sprockets, can be pulled away from the sprockets (at 3 Oclock on the rear sprocket) then need new chain. IF new chain on old sprockets can't be pulled away, then keep the old sprockets at lesat one more chain.
If new chain can be pulled away from old sprocket, time for sprockets.
--Evan
1975 CB750K "Rhonda"
Offline MoMo
  • Ride like you're invisible
« Reply #4 on: February 25, 2016, 05:54:51 PM »
That is the way I check.  You can usually have a set of sprockets last through  two chains if the chain is lubed.  If not the chain eats the sprocket
