Author Topic: Carb overflow tube question - CB750K 7a carbs  (Read 729 times)
Offline Eydugstr
« on: February 28, 2016, 02:45:21 PM »
Is there any way to fix leaking/cracked overflow tubes in carb float bowls?
Wobbly
Re: Carb overflow tube question - CB750K 7a carbs
« Reply #1 on: February 28, 2016, 04:16:47 PM »
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: February 28, 2016, 04:18:02 PM »
I've heard of people brazing them, but I've never tried it myself.
I've seen them develop lengthwise cracks, how's yours broken?
mystic_1
- John Augustus Shedd
« Reply #3 on: February 28, 2016, 04:40:32 PM »
Slide a section of brass hobby tube over the cracked pipe.  A small amt of jb weld.at the bottom will seal and hold it in place
« Reply #4 on: February 28, 2016, 05:27:33 PM »
You can also clean them well and simply fill the crack(s) with solder. They need to be clean and I would use flux. use a soldering iron or gun, not a torch. The brass tube method has yielded good reports.
Offline Eydugstr
« Reply #5 on: February 28, 2016, 07:11:54 PM »
TY for the responses, everyone.  TY for the link Wobbly - but my bike is a K2 using carbs with the casting #7a.  Do have another (used) float bowl to try but unfortunately it was a victim of too much simple green, and is now a dark shade of german panzer grey.
Haven't narrowed down exactly where the crack is, but have installed new float valves, set new floats, and double checked them with a clear tube test...everything passes except the #2 carb wants to drip from the overflow tube.  Think I'll try the brass tube idea next.
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: February 28, 2016, 07:14:23 PM »
Oh, that's savable, just wet-sand and polish it.
Of course, then you have to do all four, but then they look AWESOME  8)
mystic_1
