Author Topic: Clip-on's and Billet Triple Install - 1978 CB550k  (Read 6582 times)
Offline cgraham
« on: February 29, 2016, 07:54:07 AM »
1978 CB550k
I will be installing clip-on's and a new billet triple this week and wanted to know if you guys have any advice before I do. Is it really as simple as it seems? I've already removed the old bars and all of the hardware from the old bars, now just remove the old triple, slide the clip-on's on with hardware pre-installed, and then install new triple? Also, it seems as if the plastic is stripped on the throttle housing/switch where the pull cable threads into it, not allowing the nut to secure the cable tightly - has this every happened to anyone? thank you!
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: Clip-on's and Billet Triple Install - 1978 CB550k
« Reply #1 on: February 29, 2016, 09:43:06 AM »
You'll need to replace the steering bearings.
http://forums.sohc4.net/index.php?topic=1516.550
Also if you can't secure your throttle cable properly you should replace the switch/housing.
--Evan
1975 CB750K "Rhonda"
Offline Kenzo
« Reply #2 on: February 29, 2016, 09:53:11 AM »
It's never as simple as it seems... ;)
Kenzo
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
Offline cgraham
« Reply #3 on: February 29, 2016, 10:11:08 AM »
Oh, i've noticed Kenzo  ::). And is it absolutely necessary to change the steering bearings, or is it just suggested because it's a 40 year old bike and the front end is apart anyways?
Offline evanphi
  • Apparently I'm an
« Reply #4 on: February 29, 2016, 10:34:19 AM »
Yes it is, because there's no way to get the old race off the old stem without damaging it.
--Evan
Offline CBGhia
« Reply #5 on: February 29, 2016, 10:41:23 AM »
It sounds like he is just replacing the upper triple, so changing the bearings is not needed.
Offline cgraham
« Reply #6 on: February 29, 2016, 10:43:45 AM »
yup, just top triple. So not completely necessary (as long as they are in decent condition)?
Offline CBGhia
« Reply #7 on: February 29, 2016, 11:09:35 AM »
Yeah, but while you have it apart...  now would be a good time to put in some tapered bearings.
Offline DaveBarbier
« Reply #8 on: February 29, 2016, 04:25:49 PM »
I'm no SOHC4 veteran but I don't feel the steering head bearing install is a "while you're in there" kind of job. Replacing the top triple and adding clips ons is maybe a little over an hour and you don't need to raise the front. Replacing the steering head bearings is more like a weekend job for someone who hasn't done it before.
But it's always a good idea to do it. Just trying to give you some info on how long it'll take. I have a little write up on replacing the bearings in my '78 550 in my build thread. I forget how detailed it is, though.
« Reply #9 on: February 29, 2016, 05:59:26 PM »
Are you keeping the stock fork ears with clip ons?
« Reply #10 on: February 29, 2016, 06:48:11 PM »
I disagree with the first part of Daves post, even more so if the bearings are the original ball type, new tapered bearings are a must and are light years ahead of the useless old ball bearings Honda originally used, change them now while you have the front end apart, its not that hard and definitely shouldn't take a whole weekend ... ;)
Offline firebane
« Reply #11 on: February 29, 2016, 06:51:41 PM »
The hardest part about steering head bearings is getting the lower one off and back on. The others are super easy and just take a few minutes.
« Reply #12 on: February 29, 2016, 07:47:45 PM »
I have found that a bike with un-greased and poorly adjusted tapered rollers handles just as bad as  a bike with un-greased poorly adjusted ball bearings.  Only difference is if you let the balls go into a sorry state for very long they are ruined, not so much with the tapered rollers.
« Reply #13 on: February 29, 2016, 08:08:58 PM »
Yes but, I've seen 750's with well greased stock ball bearings still have pitted and notchy races, there's no denying that tapered rollers are far superior, and like all bearings that aren't sealed, they should be maintained properly... ;)
Offline DaveBarbier
« Reply #14 on: March 01, 2016, 02:04:46 AM »
I think it took me a weekend, haha! But maybe I just work slow and ask too many questions :)
« Reply #15 on: March 01, 2016, 02:56:34 AM »
Probably too much beer.... :P
Offline DaveBarbier
« Reply #16 on: March 01, 2016, 04:55:35 AM »
Probably, but it really feels like it helps, haha.
It should take about an hour more after the top clamp is off. Slip the forks out of the triples, remove the races, install new races, grease the bearings, install the forks, tighten the spanner nut, install clip-ons, install top clamp. If that took you a weekend Dave, we need to spend some time together in the shop!  ;D
Haha, I don't know, that "slip the forks out of the triples" could easily take a few hours for a beginner.
I'd be really curious how long it takes the OP. OP, please do this and time it! And remember, drink plenty of beer!
Either way, Cal, I'd be totally down for a weekend wrenching!
Offline DaveBarbier
« Reply #17 on: March 01, 2016, 05:31:57 AM »
I'm beginning to see a pattern with you, Dave  :D More wrenching, less quenching is your Rx
On this one I'm going to ignore the doctor's recommendation, haha. When there's good German beer to be had, the best place to do it is in the shop!
Offline CBGhia
« Reply #18 on: March 01, 2016, 05:57:53 AM »
I have nothing else to add of value, but I love this thread.   ;D
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #19 on: March 03, 2016, 07:52:26 PM »
I am with Sean on this one.  And besides, who wants to try to ride around on ruined balls?
Offline Kenzo
« Reply #20 on: March 03, 2016, 08:06:02 PM »
With age, sometimes crusty balls are inevitable...
...but they still function! :)
Kenzo
H-Town, Tejas
