Author Topic: Removing rust without chemicals  (Read 2283 times)
Offline camelman
  • Man... Myth... Legend
« on: March 06, 2016, 03:41:12 PM »
Think this will fit inside my tank? I'd like to get the last of the rust out without using chemicals.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline brewsky
Re: Removing rust without chemicals
« Reply #1 on: March 06, 2016, 03:49:39 PM »
Add a couple handfuls of screws, nuts with star washers etc into tank, wrap with an old blanket,  wait till moma's gone, stuff in dryer (on air fluff)!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline camelman
« Reply #2 on: March 06, 2016, 03:52:33 PM »
I like it, Brewsky! Probably $100k cheaper that the tool I linked to also. ;)
Offline Davidov
  • 1978 CB750 F3
    • My CB750F project log
« Reply #3 on: March 06, 2016, 04:15:27 PM »
I've seen that elsewhere, it's a LASER.
Pretty cool, just need to wait 20-30 years for technology to catch up and make a use friendly version.
-David
Offline brewsky
« Reply #4 on: March 06, 2016, 04:30:05 PM »
Google you tube and you can make one out of an old computer!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline Bodi
« Reply #5 on: March 06, 2016, 04:40:22 PM »
Must be some wild computer to have a 1kW laser inside.
Offline brewsky
« Reply #6 on: March 06, 2016, 07:44:42 PM »
Well,.... it would need to be small to fit inside a gas tank ;)
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline drumstyx
« Reply #7 on: March 06, 2016, 08:57:22 PM »
That dryer idea is incredible. Wrap it up in an old blanket and  secure and boom, gas tank shaker.
Offline Lostboy Steve
« Reply #8 on: March 07, 2016, 04:06:21 PM »
Electrolytic rust removal. Instead of washing soda use powder oxyclean. My tank looks brand new, I did have to change the anode and solution a few times though.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline jonda500
« Reply #9 on: March 07, 2016, 04:34:20 PM »
I am a big fan of the drier method - no water, no acid or any chemicals! The tank should be dry before doing it, if your tank is easy to shake things out of (early non fuel flap model) then aquarium gravel works well. After shaking out all the gravel (or removing the nuts & bolts with a magnet) you can blow out all the rust dust with compressed air- works great
John
A starter clutch thread:
Offline CB_Jeff
« Reply #10 on: March 07, 2016, 05:23:38 PM »
So, I have had good luck with evaporust, followed by baking soda and water, followed by a quart of two stroke.  Evaporust, I believe, is considered non-haz., so not very chemical-y and won't damage paint.
I have tried vinegar and run into flash rusting issues, not so much of an issue with evaporust.
After cleaning several tanks I have concluded that there is no way around it being a messy job with some sort of waste.
Offline George_s
« Reply #11 on: March 08, 2016, 07:26:59 AM »
I just picked up a '77 550F and the tank inside looks like it had been coated but the coating looks like it's coming off, it doesn't look like a smooth covering, looks like spots of the coating are missing.
What is recommended to remove whatever's in there and start over?
Thanks
« Reply #12 on: March 08, 2016, 04:07:18 PM »
Use molasses, no chemicals needed.... ;)
Offline Powderman
« Reply #13 on: March 08, 2016, 05:09:05 PM »
Thanks
You need a chemical stripper heavy in Methylene Chloride.
Offline brewsky
« Reply #14 on: March 08, 2016, 05:14:44 PM »
I've been tempted to try that, but the thought of thousands of yellow jackets coming to dinner have slowed me down?
Have you tried it outside?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
na3s
« Reply #15 on: March 08, 2016, 05:49:00 PM »
Phosphoric acid has always worked the best for me
« Reply #16 on: March 08, 2016, 06:10:12 PM »
Dave 500 uses it regularly, I had a mate who's father used to build trucks, he had a 6000 gallon, corrugated iron water tank cut in half and filled with molasses, he used to put every rusted part you'd ever seen into it including bloody huge engine blocks, chassis , what ever fitted in, everything came out spotless, it works very well on rust... ;)
Offline micol
« Reply #17 on: March 08, 2016, 06:16:35 PM »
I've used molasses on small parts. Slow but effective.
« Reply #18 on: March 08, 2016, 08:00:27 PM »
Yes, its definitely no acid but it works... ;)
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #19 on: March 08, 2016, 08:17:36 PM »
Acetone made short work of a #$%*ty Kreem liner I had to dispatch. An epoxy liner is going to need the Methylene Chloride though, and good luck not screwing up the exterior paint with 5 gallons of that stuff in hand.
USE ALL POSSIBLE PRECAUTIONS with methylene chloride.
N.
I have a motorcycle problem.
Offline grcamna2
« Reply #20 on: March 08, 2016, 08:31:20 PM »
retro,
How long does it take that molasses to do it's job? How's 'Dave500' doing ??  :)
« Reply #21 on: March 08, 2016, 08:37:45 PM »
retro,
Its not fast, a couple of weeks.? Never used it myself but have seen others use it with good results, not exactly sure how long..  Haven't spoken to Dave for a while mate, KGhost lives very close to him and sees him often, I'm about 50 minutes to an hour from those guys... ;)
Offline grcamna2
« Reply #22 on: March 08, 2016, 09:18:27 PM »
I miss Dave on the forum.
Offline jonda500
« Reply #23 on: March 09, 2016, 01:04:39 AM »
retro,
I miss dave500 on the forum too - so witty
Here's my seat pan and battery derusting in a molasses bath a couple of days after putting them in...
