To be safe you can pull the plugs. No compression on cylinders. Pull tappet covers on 1 and 4. Intake or exhaust. Hit starter and look for oil. It will be obvious. Sometimes it takes while to get oil up to the valve train, especially if you pulled the oil pump, so do not freak out if it takes a little while.
