Author Topic: Why don't gasket kits come with everything?  (Read 1269 times)
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« on: March 07, 2016, 04:54:58 PM »
Gettin ready to put the case halves together, find out that several o-rings aren't included in the Versah gasket kit.  >:(
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
Offline Davez134
Re: Why don't gasket kits come with everything?
« Reply #1 on: March 07, 2016, 05:25:56 PM »
Some do, some don't. Luckily most o-rings can be easily found at local hardware stores (just pay close attention to thickness)
Offline Artfrombama
  • CB750 K2
« Reply #2 on: March 08, 2016, 03:07:44 PM »
Seems like every time I get the time and motivation to finish this rebuild I have to stop and wait on parts for another week.  :(
Halfassed machinist
CB750E2441103
Offline Davez134
« Reply #3 on: March 08, 2016, 04:59:30 PM »
Yep, I hear ya. I restored mine from only frame/motor, trying to find all other parts. What helped me was doing a "dry run" mock up of as much as I could, so I could see what small parts I may need well before final assembly.
Offline drumstyx
« Reply #4 on: March 08, 2016, 05:06:44 PM »
Fortunately it seems most o-rings and fasteners have size listings in the fiches. If you can get a reliable local source for small quantity fasteners and seals, it's a non-issue.
na3s
« Reply #5 on: March 08, 2016, 05:57:35 PM »
If you're ordering O rings, the viton versions are usually worth the small upcharge.
Offline Artfrombama
  • CB750 K2
« Reply #6 on: March 08, 2016, 07:21:28 PM »
Most is right. One elusive O-ring that I can't lay my hands on is the big round plug in the bottom of the case, it's like a 3mm x 72mm (+/-)
Not on any fiche that I've found to date, no local suppliers have one and really don't want to try something that's "iffy".
Halfassed machinist
CB750E2441103
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: March 08, 2016, 08:35:27 PM »
I've never even pulled one of those out.  Never seemed worth the probably hassle, so long as they're not leaking.
mystic_1
- John Augustus Shedd
Offline Artfrombama
  • CB750 K2
« Reply #8 on: March 08, 2016, 08:48:44 PM »
mystic_1
Seeped just enough to leave 2-3 drops of oil on the floor per night. Considering having the thing welded in.
Halfassed machinist
CB750E2441103
« Reply #9 on: March 08, 2016, 10:30:05 PM »
mystic_1
Loctite?
Offline Artfrombama
  • CB750 K2
« Reply #10 on: March 11, 2016, 07:34:16 PM »
mystic_1
Loctite?
Sanded the corrosion off and used some of THIS STUFF
Halfassed machinist
CB750E2441103
