Author Topic: Your opinion ..how does a frame kit affect the bikes value?  (Read 5870 times)
Swoop
« on: March 09, 2016, 05:09:16 AM »
I know for a daily runner it makes sense....but what about a restored or refreshed bike that has more value?
Just curious whether to put one on my k0
Thanks
Steve
Offline greenjeans
  • 1972 CB750K2
Re: Your opinion ..how does a frame kit affect the bikes value?
« Reply #1 on: March 09, 2016, 05:25:51 AM »
If it were me, and on a K0, I would not touch the frame.  If it's a rider, go for it.  Investment bike - leave alone.
« Reply #2 on: March 09, 2016, 07:16:09 AM »
If you want your K0 to appreciate to a high value, dont do it.
Swoop
« Reply #3 on: March 09, 2016, 07:32:02 AM »
Thank you gents.  :)
DH
« Reply #4 on: March 09, 2016, 07:35:44 AM »
Yup, once you cut it, its never the same. Rider/ rat, or non stock, or anything that isn't special, go for it.
« Reply #5 on: March 09, 2016, 07:50:04 AM »
My question is how does it affect handling?
Offline Davez134
« Reply #6 on: March 09, 2016, 08:20:57 AM »
I agree with everyone's assessment about value. As far as handling, I've had a 72 750 wits and without and have noticed no difference in handling or feel. (As long as every piece that was cut is still braced afterward) Just my personal experience.
« Reply #7 on: March 09, 2016, 08:53:53 AM »
I think the frame kit will not adversely affect value of any non-restoration bike, and will add utility to the bike.
« Reply #8 on: March 09, 2016, 10:14:30 AM »
For any std CB750 restored to OEM shape, the frame does not need the frame kit. Just restore and put it together. Different with a modified engine and need of lifting valve cover, head and cylinder for changes and updates.
I did it when I had to lift head and replace cyl studs. I did not want to pull engine again after a few months since mounting it. I have had good use of it.
Franks (754) kit is good when it can be done when really needed whith engine and carbs still mounted. No welding and painting
Offline firebane
« Reply #9 on: March 09, 2016, 11:51:59 AM »
My issue with frame kits is the damn cost. I realize that a person is making it and between parts, labor and time that it adds up. But $200 for a frame kit is also a rather large chunk of change and if someone is skilled enough and has the tools it can be done quite easily.
Regarding value.. I echo the same thoughts... If the bike is completely original and never been touched or cut... then don't do it.
« Reply #10 on: March 09, 2016, 12:40:51 PM »
200 is not much if you can avoid puliing the engine for a small job as lifting the valve cover and head 2-3 times. It's rather cheap when pulling engine will bring drain oil and fill with new and new filter. With frame kit not needed.  I pulled my engine out of the frame after I had removed, head, cylinder and cyl studs and clutch. Easy to lift engine with a strap around the case and lift it out of frame alone. I friend helped me to avoid cracking my back when lift the case up on the work bench. Much more space when upper fram tubes are off.
Before frame kit I pulled engine several times, did the job and in with it again. Frame kit for repeated work.
Wait with frame kit. Order from Frank when you need to lift the valve cover urgently.
Offline firebane
« Reply #11 on: March 09, 2016, 12:57:36 PM »
I spoke to Frank about the frame kit and I decided to do it myself because I had to pull my valve cover badly and because of the cost I will be doing it myself.
Offline Bodi
« Reply #12 on: March 09, 2016, 01:01:03 PM »
As a general rule, any modifications will reduce the value of a classic bike.
An iron clad rule - "hot rod" modifications will never increase resale value to equal their cost. On any bike.
« Reply #13 on: March 09, 2016, 01:58:09 PM »
Thats a good question Steve, everyone seems to be hung up on the frame cuts, with the bolted or clamped in sections, this isn't a problem, the problem lies in the cross brace that ties the 3 rails together, this is the important bit, look at a boldor or GS1000/1100 frame and see the cross bracing in this area, they were much better frames.
« Reply #14 on: March 09, 2016, 02:43:50 PM »
Good info, thanks Dave. Which kit did you use?
Agreed, the GS had better frames, larger motors and more of a "sport bike" than the CB
[no offence intended!].
Will the frame twist with the kit?   I dont have much choice, my current project came to me with what I call a "shade tree kit"!
Yes, they took pipes and bolted it on. And didnt tie in in at all.
My plan is to acquire parts of another frame and install "Franks Kit".
« Reply #15 on: March 09, 2016, 02:49:26 PM »
Go ahead and use one Steve, I'd fix the cross brace. I think, as far as using these kits on the street, you'd be hard pressed to fell any differences in handling, I think a good rider pushing very hard on a track might feel some difference but on the road, I doubt it... Its my anal retentiveness that makes me think about these things... ;D ;)
Offline Davez134
« Reply #16 on: March 09, 2016, 03:24:18 PM »
I used the Gordon Kit. Mainly because I was starting with a bare frame and am a competent welder, so it was easy for me. As stated, maintaining the triangular bracing is a must for me.
(Triangle braces not yet installed in this pic, I was just too excited to take the picture )
« Reply #17 on: March 09, 2016, 03:29:17 PM »
Looks great Dave.  I've had a Gordans Kit, it was very well made.  I have Franks Kit on the shelf, so I'm going with that one. It's not a race bike, so I'm sure it will be fine.
Offline Davez134
« Reply #18 on: March 09, 2016, 03:41:40 PM »
Yeah, with the right size tubing, franks kit would be an easy install. You could also get some angle steel and remake that hacked up center bracing. I'm sure it will turn out great
« Reply #19 on: March 09, 2016, 03:46:45 PM »
Unless you are doing a Concours restoration it should NOT have a negative valuation and potentially positive but not likely.
« Reply #20 on: March 09, 2016, 04:28:56 PM »
Ironically, this chopper build thread, provides some insight into why I think a frame kit of any kind is always a bad idea (except perhaps for a drag race only bike).  Its a really cool thread anyway, so I will link the pertinent page for your perusal...
http://forums.sohc4.net/index.php/topic,68952.75.html
Offline BPellerine
« Reply #21 on: March 09, 2016, 04:53:09 PM »
sean,I read that build thread,and one must remember that the front tubes were cut therefore making the rear appear really weak,I am not advocating anyone taking the top rails out,but I drove my bike for awhile wihtout top rails and no real diff while riding at legal speeds,if you were putting a lot of side pressure on the frame it would be flexable I think.a frame kit would at least be as strong as the original if done right but the resto guys do not like that stuff at all.billp
1978 CB 750K ard and webers
another anfob
« Reply #22 on: March 09, 2016, 05:24:12 PM »
Your probably right, but I still ain't buying it.
Offline mystic_1
  • 1970 CB750K
« Reply #23 on: March 09, 2016, 07:19:55 PM »
Sean I'm guessing you're referring to my comments in the following post:
http://forums.sohc4.net/index.php/topic,68952.msg1783791.html#msg1783791
Just to expound a but more about the blasphemy I had just conducted upon my frame, the point where the main backbone tube meets the cross brace at the front of the seat, is all just made of sheet metal.  There are two pieces that form this joint, an upper and a lower plate, which are shaped around the auxiliary backbone rails and the main backbone end, then welded in place.  This is what was bending when I was doing the above, you'll probably be able to see the deflection in these pieces in later pics.
And this is the main problem with cutting out the auxiliary backbone rails - they're not really "auxiliary."
They are, in fact, far far stronger than the way the main backbone tube is "secured" at its end!!!
When you remove these, the only thing holding the backbone together is the sheet metal shape described above.  Most of the bottom plate isn't even there, there's large ventilation openings down there to keep water from accumulating inside the gusset.
Go on out to your bike and knock on these pieces with your knuckles, and then tell me if that's the only thing you'd like to have holding your steering head in place.
Me neither.
mystic_1
I have definitely come to believe that the side rails in the backbone contribute a significant percentage of the backbone's strength.  Without them, the rear of the backbone tube is only held in place by the sheet metal gussets, not a particularly strong or rigid joint IMHO.  That's why I welded mine back in after the changes, and I'm betting (hoping ;) ) that it's at least as rigid as stock up there again.
I think with the bolted in frame kits you're loosing some rigidity since a bolted connection is rarely as rigid as a welded connection, at least not in all planes of force.  How much weaker than stock is it?  I think that's impossible to say without some pretty serious maths.
mystic_1
- John Augustus Shedd
« Reply #24 on: March 09, 2016, 07:37:43 PM »
yup
