Author Topic: lower race?  (Read 1027 times)
Offline irish44395
lower race?
« on: March 12, 2016, 10:28:03 AM »
I am looking for a way to get the lower race off the steering stem.
thanks
Pete
Offline mystic_1
  • 1970 CB750K
Re: lower race?
« Reply #1 on: March 12, 2016, 10:37:18 AM »
I use the steering stops as fulcrums and a pair of large screwdrivers.
mystic_1
- John Augustus Shedd
Offline navydad
Re: lower race?
« Reply #2 on: March 12, 2016, 10:39:35 AM »
I just changed mine last week. Used a hammer and a long punch and tapped it off in less than a minute. If it is grimy/rusty you can use a small torch to heat the race and then tap it off. I have had really nasty ones where I used my dremel tool with a cutting disc and cut a slot in the race and then tapped it off. Take care not to nick the stem with the cutting wheel. I only had to do that once, 99% of the ones I have done just needed the hammer and punch.
Offline irish44395
Re: lower race?
« Reply #3 on: March 12, 2016, 01:41:27 PM »
Thanks the pics are great I am just going to have to wait until Monday for I don't have a good vice to hold it.
 need to take it to work for sandblasting any ways.No rust should be easy to do with the right tools.
thanks again
Pete
Re: lower race?
« Reply #4 on: March 12, 2016, 01:51:57 PM »
 I've got a heavy sharp duty putty knife I can tap in behind it to get it loose then use pry bars.
Offline riverfever
Re: lower race?
« Reply #5 on: March 12, 2016, 08:19:13 PM »
I used a small punch and a hammer and just kept at it for several strikes at 12 and 6. Or 2 and 8. You get it. Easy.
