Author Topic: Ever find this in your fork?  (Read 1042 times)
Offline bigring
  • Newbie
  • Someone please tell me what to do
« on: March 14, 2016, 06:31:53 PM »
Hi all,
Just getting back to my bike after being away from it (and here) way too long.  Kids, family, job, an addition and a swimming pond that I built myself have kept me busy the better part of the past year and a half.
Getting the front end cleaned up and worked on.  Pulled off the forks and began taking them apart.  Undid the fork bolt and the spring sprung up fairly quickly.  Directly under the fork bolt were these - one in each fork:
The only thing that I can think of is that the PO attempted to use these as spacers.  I measured the springs - one was 18 1/2" and the other was 18 5/8" - both compressed quite a bit.  The Clymer manual that I am using states that you should replace them if less than 19 1/2".
I did a little look on the interweb and these "parts" are used as fasteners in cabinets, furniture, desks, etc.  See the link :  https://www.knapeandvogt.com/joint-fasteners
Offline CB650CPastor
Re: Ever find this in your fork?
« Reply #1 on: March 14, 2016, 06:50:18 PM »
I'd say you're probably right. Some crazy PO used them as spacers to make up for saggy springs...
Tim
Current:1980 Honda CB650C Custom, 1969 Toyota Corona Deluxe Sedan
Past: '07 Honda Rebel 250, '80 Yamaha XS1100 Special, '69 Honda CB160, '67 K15 Suzuki Hillbilly, 1971 VW Super Beetle...
« Reply #2 on: March 14, 2016, 09:25:51 PM »
 I'd cut some PVC pipe spacers, stack em in and go ride. it was common to cut an inch off then put in an 1 1/2" spacer to stiffen up an old set of springs.
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #3 on: March 15, 2016, 01:06:48 AM »
When I brought my bike home the +6" forks had to go. Inside the fork tubes was a galvanized pipe (still had threads on one end) and a cutoff broom handle spacer.
Hey whatever works, right?
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
Offline bigring
  • Newbie
« Reply #4 on: March 15, 2016, 06:49:46 AM »
So would you recommend a new set of springs?  Or like Don said, just cut some spacers (out of a better material I would think) to make up for the difference in compression to the length they should be?
I know many lower their forks by cutting down the spring and adding a spacer to the dampener end.
Thanks fellas.
« Reply #5 on: March 15, 2016, 06:57:05 AM »
If the springs are original, yes, I would recommend new springs.
I put Progressive's in my K4 last year. BTW - they came with a couple pieces of PVC to use as spacers but I did not use them.
Offline bigring
  • Newbie
« Reply #6 on: March 16, 2016, 02:48:33 PM »
Cheers Stev-O!
