Author Topic: LED Turn Signal Diode Install - one more time, please!  (Read 6887 times)
Offline Chachi
Re: LED Turn Signal Diode Install - one more time, please!
« Reply #25 on: March 21, 2016, 06:14:52 AM »
calj... Had to look up where you were... Richmond. I used to live there. Plenty of places I'd want food from there too! I try to ride up at least once a year (Rt. 5). I'll you know if I do this spring or summer.
For grounding the dash bulb and the signals... I added a ring terminal and got them on the headlight bucket bolts behind the grounding nut. Is that the best place? I know on the back of frame near the battery there is a spare ground with a spade terminal. I was using that for a brake light modulator, but now I'm using it on the EP34 flasher and grounding the modulator on the frame with a ring terminal. I wasn't sure if there was anything else spare in the bucket for grounding.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Chachi
« Reply #26 on: March 21, 2016, 06:40:21 AM »
Now that is a project I would buy you lots of stew and doughnuts for!
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
