Author Topic: Weird intermittent spark  (Read 6351 times)
Re: Weird intermittent spark
« Reply #25 on: March 19, 2016, 12:21:12 PM »
Caps resistance ideally is around 5KΩ. 10KΩ is the max! BTW, what type of sparkplugs do you run, with or without R(esistor)? HT leads measured from one to the other (caps removed) should be around 14-15KΩ. So with caps attached you should read around 25-30KΩ in a secundary circuit. Primary circuit is around 4,7Ω.
« Last Edit: March 20, 2016, 03:39:39 AM by Deltarider »
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #26 on: March 19, 2016, 12:26:33 PM »
First cap.
Sent from my SM-N900V using Tapatalk
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #27 on: March 19, 2016, 12:30:49 PM »
Next cap I checked: orig on cyl 1 11.8
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #28 on: March 19, 2016, 12:38:12 PM »
Then 2 cyl read 5.5, 3 cyl read 14.4.......caps?
Gus, Austin, MN.
« Reply #29 on: March 19, 2016, 12:54:58 PM »
Well this was my first start up for bike. Cleaned carbs, bench sync, gapped plugs at .26,
Why dont you think you need to replace the parts for a proper tune up?
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #30 on: March 19, 2016, 12:56:55 PM »
Ya I'd love to replace every part on the bike, but I just don't have the money. So if it works, I plan to use it.
Gus, Austin, MN.
« Reply #31 on: March 19, 2016, 01:02:40 PM »
Dont need to replace every part.  Plugs, caps, points and condensers - $100 and I bet that bike will be running good.
I've been there, thought the points "looked" good, bike wouldnt run right. Changed points and condensers, guess what? Started right up and ran very good.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #32 on: March 19, 2016, 01:03:28 PM »
Ya. Your probably right.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #33 on: March 19, 2016, 01:09:10 PM »
Thinking right now of putting it away till then. I just can't put any more cash into it right now
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #34 on: March 19, 2016, 01:09:23 PM »
Are those caps way off though?
Gus, Austin, MN.
« Reply #35 on: March 19, 2016, 01:30:23 PM »
Best is step by step if we want to learn something. Caps that read more than 10KΩ are no good. Personally I don't want them over 8KΩ. Mind you, that is in combination with plugs without R(esistor). Furthermore caps in one circuit (1+4 or 2+3) should not show more difference than 1KΩ resistance.
Plugcaps do deteriorate in use but are about the cheapest parts.
« Last Edit: March 20, 2016, 04:30:43 AM by Deltarider »
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #36 on: March 19, 2016, 01:46:59 PM »
Resistor screws in at top of plug, right? I think I'll wait a bit and when I score some case replace all spark related stuff and see if it helps.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #37 on: March 19, 2016, 03:19:17 PM »
Thinking about how it sounded and seemed to run ok on three cylinders with junk caps, this thing is really gonna roar when I get back at it
Gus, Austin, MN.
Offline camelman
  • Man... Myth... Legend
« Reply #38 on: March 19, 2016, 11:33:55 PM »
Sdsbassist, those caps are pretty cheap at various places. I personally like 4into1.com and they have low shipping costs. You'll get a much better spark and performance from each cylinder if you change your caps out, and you should probably change them all if three out of four measure high. Make sure to trim off the last 1/4" of the spark plug wire when you put new caps on so that you get a good contact with the wire and don't introduce more resistance to the circuit.
A little background: as the resistance of the caps increases, it is more likely that you'll get arcing through the spark plug wire insulation to whatever "ground" is nearby like the engine, frame, other wires... This is because the electrical charge is looking for the easiest path to ground, and the resistor cap is putting up a bigger and bigger fight as resistance through it increases.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
« Reply #39 on: March 20, 2016, 12:53:21 AM »
Do it step by step so you (and we) will learn what caused your problem. There are owners who just throw a lot of money in their bike by replacing all related stuff in one time, hoping the bike will see and value the offer. Alas, a bike is not like that.
« Last Edit: March 20, 2016, 03:41:54 AM by Deltarider »
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #40 on: March 20, 2016, 05:44:15 AM »
The caps are obviously bad. I think I'll start with those and ngk plugs
Gus, Austin, MN.
Offline Vinhead1957
« Reply #41 on: March 20, 2016, 06:12:26 AM »
If you changed the plug cap and plug with a working cylinder and nothing changes, then swap coils and if the problem moves to another cylinder it is the coil.  It is a low probability but they sometimes go bad. One set of points fires two cylinders so the problem is not there.    Another option is to check spark with the plug out against the head.   If it is a nice blue spark look into the carb.   Bad fuel or varnish clogged carb
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #42 on: March 20, 2016, 07:28:13 AM »
Yes. I ordered new caps and plugs. If that doesn't work I will move to points and condensors
Gus, Austin, MN.
Offline Vinhead1957
« Reply #43 on: March 20, 2016, 07:50:39 AM »
If so, all he would need to do is move a cap and cylinder 1 would fire. Nothing is proven yet.  Suspect caps but prove it
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #44 on: March 20, 2016, 07:55:14 AM »
I'll let you guys know. That's what bothered me too. Switched wired and still jack squat. My plan is to get caps and plugs and do a once over on carbs too to see if there is anything suspect. If it is carbs, I need new caps and plugs  anyways.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #45 on: March 20, 2016, 09:11:07 AM »
Yes...I agree
Gus, Austin, MN.
« Reply #46 on: March 20, 2016, 01:13:05 PM »
I had intermittent ignition on 1 cyl 1 year ago. New wires were the last to replace. Dynatek surpressed graphite wires... Not a good choice in my case, CU wires and NGK 5kohms caps solved that tricky problem.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #47 on: March 20, 2016, 01:27:11 PM »
Tha s for the input pewe...I'm excited to see how the new caps react. Is there a good way to make sure they have good contact?
Gus, Austin, MN.
« Reply #48 on: March 21, 2016, 04:26:06 AM »
I finally noticed that which cylinder that had intermittent function when it was not functional during a longer time and exhaust cold.
Used another wire and it worked better direct. Easy to change wires when I use Dynatek coils (5ohms)
Offline Gene
  • Chat enuf you too can be a
« Reply #49 on: March 21, 2016, 11:54:17 AM »
Do you mean to tell me that these bikes are not like the old Gods? I've been going at this entirely the wrong way . . .
*1973 CB750K3 (Bow)
