I've got a lot on my other computer. Well not as many as I should hvae taken. Once I got the parts back from the painters and such, it was marathon time to get it together. I was going to take shots of the home porting job I did on the head for MRieck, but that too got bypassed in haste to buttom up the top end.
But for cautionary decal location I made note of those before media blasting and such. Tuesday I'll try to post whay I got for disassembled picts. There are two that go on the chain guard for tire and chain information. The battery vent tube routing and carb overflow decals were stuck on the inner fender and were placed haphazardly. The battery tube was at about a 25 degree slant from centerline and the carb overflow about 40 degrees or so. Looked like a worker was eager to go home that day. And they were indeed the originals.
Here's a couple that I found on this machine. The helmet holder decals are correct, as is the tank warning decal. The oil decal is incorrect and should be on the actual tank top - not on the sidecase. I put this one on the sidecase as a throwback to the earlier K models. No real reason, I just felt like it.
