SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Needle Clip Settings on a 1974 cb550
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Needle Clip Settings on a 1974 cb550 (Read 1658 times)
rheilman
Full Member
on:
November 12, 2006, 05:14:42 PM »
Hi everyone,
I am in the process of rebuilding the carbs of my 74 cb 550.
Can someone tell me the setting for the spring clips on the needles? The ones I removed were set at the second groove from the bottom (pointy end), but I dont know if someone else may have messed with them in the past, and the bike was running quite rich before I pulled the carbs. Any help is appreciated!
Thanks
Ray
Logged
kettlesd
Guest
Re: Needle Clip Settings on a 1974 cb550
Reply #1 on:
November 12, 2006, 05:37:32 PM »
Middle position is stock. Lowering the clip raises the needle and may explain your rich condition.
Logged
rheilman
Full Member
Reply #2 on:
November 12, 2006, 06:06:55 PM »
Thanks kettlesd. I have found a couple different ideas about the clip position in other threads. Several have indicated one up from the bottom, but a couple have said the third slot... I was hoping the ones i pulled off of the bike were wrong, as this would explain my persistantly rich condition, despite checking other obvious problems. I will try the middle position unless anyone else thinks a different position is correct.
Ray
Logged
kettlesd
Guest
Reply #3 on:
November 12, 2006, 06:13:47 PM »
Yeah,
Stock tune - pipes, plugs, Carbs, Airbox, filters (no K&N's), etc, etc. then Middle Clip.
Let us know how you make out with it.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
