Author Topic: Brembo Caliper P108 Blueprint  (Read 7804 times)
Offline Artracing
« on: March 24, 2016, 06:24:43 pm »
I need to design a rear caliper bracket for Brembo P108. I need the illusive blueprint of the of the P108
Can anyone help? I can't find it anywhere.
Brembo will not supply it. Go figure
Rob
Re: Brembo Caliper P108 Blueprint
« Reply #1 on: March 24, 2016, 07:31:44 pm »
Can you get an existing bracket and transfer punch it?
Dual acting with fluid transfer holes can be a pain to drill properly..
« Reply #2 on: March 24, 2016, 07:51:14 pm »
Surely you don't need any blueprint to build a caliper mount...?
« Reply #3 on: March 24, 2016, 07:57:36 pm »
On the Pm ones there is about7otlr more holes for the tiny dual piston caliper....very easy if you have an existing bracket to lay over and transfer punch..
Offline Artracing
« Reply #4 on: March 24, 2016, 08:17:20 pm »
No I don't, lol  if I want to use hillbilly methods, but I happen to have a $3000 CAD system  and $30,000 CNC
Hence, I can bang out a perfect bracket in and hour.
All I need is a few dimensions that they designed the caliper to.
Its amazing they create a product to sell and you have to reverse engineer it. Go figure
Offline Artracing
« Reply #5 on: March 24, 2016, 08:21:14 pm »
Unfortunately I don't have a bracket to start with. That would be a solution.
Thanks
« Reply #6 on: March 24, 2016, 09:04:15 pm »
Hmmm, I wasn't thinking hillbilly or thrown together what so ever,  you don't need any blueprint of the caliper to make a relatively simple bracket. I'm still not getting you, all you need is a few simple measurements then draw something up on Auto cad or whatever program you need for your CNC, its not rocket science, {or am I missing something here?} Don't you have the caliper yet..?.., I'm about to do something similar for a 750/4, an underslung bracket for a rear caliper incorporating the rear spacer as well.  Don't over think it, its far from the hardest thing to design...
« Reply #7 on: March 24, 2016, 09:11:57 pm »
Thanks
Do you have the caliper? Use the CNC as a CMM to locate hole centers. ;)
Offline Artracing
« Reply #8 on: March 25, 2016, 03:57:19 am »
Thanks
I don't have the caliper yet. I will most likely do that. If I had print, I could have the bracket don by the time it shows up.
Thanks
Offline Artracing
« Reply #9 on: March 25, 2016, 04:08:59 am »
I don't have the caliper yet. I just ordered it. I hear what your saying, but with a print, I would have the bracket ready to bolt on when it showed up.
No, I'm not over thinking it, I just have the tools to make it perfect. Locating a print for the caliper is not unreasonable request. I thought!
I'm making a underslung bracket also. I could make it for you on my CNC , but looks like you have a handle on it.
« Reply #10 on: March 25, 2016, 07:07:07 am »
I don't understand this  ;D  but no, neither am I offended! I truly am the hillbilly who hand builds stuff and eyeballs everything. I'd love to have someone like you close by! When I die I want to come back as a top shelf machinist with toys galore!
Good luck finding your blueprint, I can't even suggest where to look.
Offline calj737
  • I refuse...
« Reply #11 on: March 25, 2016, 08:06:16 am »
Please don't take this harshly, but, do you honestly think a company should invest significant time and money into designing, testing and producing products for sale and then turn about and publish the design data for them? This would enable anyone to recreate their products and eliminate or at least, greatly reduce their sales. Of course you'll have to reverse engineer it. That's exactly why they make it so difficult. This forces people to at least buy 1 of their products before they siphon off their hard work.
Last time I looked, most companies like Brembo weren't in the business of "share-ware".
Offline kmb69
« Reply #12 on: March 25, 2016, 08:40:25 am »
I suspect the real reason they don't publish the data is related to product liability. Brakes ARE KINDA IMPORTANT regarding safety. Brembo designs their brake systems to replace a specific application and they probably carry product liability insurance for same. They have absolutely NO CONTROL of the customized application of their product. Publishing even the installation template would necessarily INVOLVE them in "OUTLAW" applications which may or may not be of sufficient design and the resulting safety or lack there of. Hence they are making every attempt to avoid/prevent any complicity in any frivolous legal implication resulting from some Moron's misapplication of their product.
« Reply #13 on: March 25, 2016, 10:30:12 am »
You always gotta rain on somebody's parade. ;) ;D ;D ;D ;D ;D ;D
Offline kmb69
« Reply #14 on: March 25, 2016, 10:43:53 am »
Thanks, that's just the kind of guy I am!  ;)  ;D  8)
« Reply #15 on: March 25, 2016, 10:49:07 am »
Some people should not be adapting calipers.. And I dont mean this case..
 Failing that you find the info, i would use transfer punches, and threaded tranfer screws.. A pita but will work...
Offline turboguzzi
« Reply #16 on: March 25, 2016, 11:40:32 am »
i do all my bracket design on an even more expensive CAD system than yours (Creo 5) , and yet, still simply measure everything with a caliper off the caliper itself :)  sounds like you have to have that bracket right now, otherwise ....
In building bikes, patience is paramount....
I've seen form other post that you are not that receptive to other peoples friendly advice, nevertheless, here is mine: Grimeca used to do many "Brembo replica" calipers like the P08 and P05 look alikes that have the same dims and between holes distance. It's a good bet they did also a P108 look alike and i've come across Grimeca Pdf catalogs that have complete caliper drawings, dig the net a bit, you might find it.
Will dig my hard disc too, will give you a copy if you promise to be nice to us hipo sohcers :)
« Reply #17 on: March 25, 2016, 03:28:34 pm »
With some of the sh1t i've seen on this forum {not this thread} frank, some people shouldn't be allowed to work on motorcycles, period.... ;D
« Reply #18 on: March 25, 2016, 03:33:50 pm »
Got it, I assumed {you know how that goes :P} you already had the caliper. Wasn't the P108 a Lockheed copy..?, Also check Grimeca as TG has suggested....
Offline slikwilli420
  • Master of Disaster
« Reply #19 on: March 25, 2016, 03:58:25 pm »
Click on the link and download the drawing. Took me almost two minutes to find it. Expensive CNC equipment clearly doesn't replace the ability to sleuth the Internet.
https://www.apracing.com/product_details/motorcycle/brake_calipers/solo_and_classic_machines_plus_sidecar_2_piston_caliper/cp2696-38e0.aspx
Offline kmb69
« Reply #20 on: March 25, 2016, 04:44:24 pm »
Ain't that the gospel truth. Curious Slik, how did you cross that over from Brembo P108?
« Reply #21 on: March 25, 2016, 04:50:32 pm »
Kmb, the p108, grimeca, and multiple ap racing units all have the same spacing. Even super exotic stuff like fontana and scarab are the same. Ap racing did it first, set the world on fire and everyone else followed suit.
Offline kmb69
« Reply #22 on: March 25, 2016, 05:30:42 pm »
Very interesting. Thanks.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #23 on: March 25, 2016, 05:40:02 pm »
Well ain't that great but it kinda shoots kmb69's paranoid liability concerns all to he!!
« Reply #24 on: March 25, 2016, 06:02:00 pm »
Its not Brembo Jim..?  Also, why use the word "paranoid" to justify your  post..? Cal basically said exactly the same thing, It seems you've never heard of "intellectual property" or simply don't understand it.... ::)  And by the way, that link is not a "blueprint"....  Try again...
