Now I'm not going to pull the motor just for paint at this point but I brought the bike to my buddy's shop for a leak down test.
For those that are not aware, a leakdown test will tell you more than a compression check.
Basically, the cylinder is put at TDC on the compression
stroke (valves closed and piston at top), then pressurize the cylinder to 100psi. A gauge on the tester that will tell you what the cylinder is holding after 10 min.
My motor failed miserably! I dont have the numbers in front of me but #3 was at 50% [Ideally, you want 90%].
So the top end came off, it's nice having the frame kit! So now, I'm in "machine shop jail", getting a valve job and I'll find out tomorrow if the jugs will be within spec after a precision hone.
I'm hoping to hone and rering, but if I'm not lucky, it will be getting the ebay $130 Big bore kit!
The tensioner was quite worn, I have a few spare, and on a good note, the cam and chain look fine.
![](http://i980.photobucket.com/albums/ae288/smeriggi/K3%2045_zps9a5adgce.jpg)
![](http://i980.photobucket.com/albums/ae288/smeriggi/K3%2046_zpsvdrajxwk.jpg)
