Author Topic: 81 CB650 build thread  (Read 2152 times)
Offline basketcase81
« on: April 02, 2016, 08:37:56 AM »
I just typed out a pretty long post and it didn't save so I'm gonna keep it short this time
I got this bike for free. After getting the electrical fixed and cranking over I discovered that I had zero compression. After tearing the head down I discovered that all valve hit the pistons.
I plan on buying a good used head instead of rebuilding. Still debating whether or not to do Rings while head is off (I probably will)
Couple questions followed by some pictures
1 The cam removal was the hardest part because there was no  bolt for the=e tensioner. I'm thinking this may be cause for the damage. Thoughts?
2. What else should I look at before putting it back together?
3. CB650C parts will fit the regular CB650 right?
4. Whats the easiest way to make this a hard tail?
5. Any other input is appreciated. I will probably need more help along the way so if you could follow this threads that would be great
« Last Edit: April 02, 2016, 08:52:05 AM by basketcase81 »
Re: 81 CB650 build thread
« Reply #1 on: April 02, 2016, 09:06:43 AM »
If you are going to replace the head, you have the option of buying a 80-81 head, which is spaced to use the stock CV carburetors, or to swap in a 79-80 head, which uses differently spaced stock carburetors that use the same spacing as a 750 (giving you more options for performance).
« Reply #2 on: April 02, 2016, 09:16:19 AM »
I already bought the head, its from an 81 which is fine. I just wanna get this thing going so I can ride
Offline calj737
  • I refuse...
« Reply #3 on: April 02, 2016, 11:30:43 AM »
If you had no compression, and the valves were hitting the Pistons, my bet is on the cam being 180* out when installed. The
At way, you'd have open valves during full compression (causing no compression) and this striking the Pistons. You might investigate this before rebuilding any further...
« Reply #4 on: April 02, 2016, 01:33:19 PM »
i cant really investigate any further because it is already tore down. It wont matter anyway as long as I out the cam in right  when I rebuild, right? Or am I missing your point?
Offline calj737
  • I refuse...
« Reply #5 on: April 02, 2016, 01:52:14 PM »
Nope, you're right.
« Reply #6 on: April 02, 2016, 07:31:42 PM »
Cal, I can't believe you typed this. :o ??? ??? ???
« Reply #7 on: April 03, 2016, 07:17:42 AM »
What do you mean?
« Reply #8 on: April 03, 2016, 06:11:50 PM »
What do you mean?
The cam can't be installed "180* out" on these motors. ;)
You mentioned a missing bolt for the tensioner; this may have caused the problem?
« Reply #9 on: April 03, 2016, 06:15:19 PM »
Thanks for the info
So, do you agree that just replacing the tensioner and head wouldnt be a bad choice?
« Last Edit: April 03, 2016, 06:19:28 PM by basketcase81 »
« Reply #10 on: April 05, 2016, 02:48:41 PM »
is there some kind of trick to getting the cam chain tensioner into the slot?
« Reply #11 on: May 01, 2016, 01:08:01 PM »
Nope, you're right.
ok, so finally got the thing most of the way back together, minus oil pan and clutch cover. I did a compression test.....
I got 80 on #1, 90 on #2, and ~110 on #3&4
This bike was sitting for an unknown amount of time and I am in the process of rebuilding. PO didnt put the cam tensioner in correctly and bent all the valves. I got a good used head and these are the numbers i got. Should I keep going or should I look for something else causing those low numbers?
Offline calj737
  • I refuse...
« Reply #12 on: May 01, 2016, 04:28:20 PM »
Low compression numbers are not unusual for a motor that's sat a long while. Also, you need to be WOT to run full compression number checks. And of course, your valves need to be adjusted properly...?
« Reply #13 on: May 01, 2016, 04:49:23 PM »
no carbs so it is WOT, and as far as i know the valves are set
