Author Topic: Bike popping out of gear? Update!  (Read 8253 times)
Offline 75 super sport
Re: Bike popping out of gear?
« Reply #25 on: April 03, 2016, 08:45:10 PM »
So, say it is #1, where would I start? Could it be that I'm not engaging my clutch fully, and it is not allowing it to go all the way into gear? Or what are the possibilities. About #2, the thought has always been in the back of my mind that the bike sat because of an issue. Usually things do not get put away and abandoned for no reason. I really hope it's #1, but #2 makes sense too unfortunately.
"Smoke em if ya got em"
Offline goldarrow
  • one day, i'll be an
« Reply #26 on: April 03, 2016, 08:45:51 PM »
Is anything coming to your head scottly?
3 things come to mind:
1. You are not fully shifting the bike into gear.
2. I hesitate to post this, but perhaps the reason the bike sat unused for so long was due to the same shifting problem. Some bikes came from Honda with improperly installed snap rings on the transmission shafts, which could pop out of their grooves and allow erratic transmission operation. I was unfortunate to have one of these, which decided to shift into gear by itself while cranking the motor, folding up the kick-stand and falling on top of me. The fix was to split the cases and re-install the snap rings in the proper direction. Hopefully your problem is #1.  ;)
3.  PO raced the bike and hard shifted, not using clutch
FTFY ;)
CB550 K0
Online scottly
« Reply #27 on: April 03, 2016, 08:50:25 PM »
Popping out of gear under heavy load is usually due to worn dogs, not worn or bent forks, in my experience with 750's. Even worn dogs don't cause popping out of gear under light loads.
« Reply #28 on: April 03, 2016, 08:55:36 PM »
That's why I was curious too. Even letting out the clutch to start going it pops out.
Offline goldarrow
« Reply #29 on: April 03, 2016, 08:56:58 PM »
My 75 750k popped out of 2nd under light load, splitter the cases and found worn shifter fork and drum.  Here's my project thread if OP wanted to read about it. http://forums.sohc4.net/index.php/topic,114817.175.html
CB550 K0
Online scottly
« Reply #30 on: April 03, 2016, 08:59:14 PM »
Once moving down the road, you don't even need the clutch, if you know what you're doing. ;)
I would rule out the easiest first: the external linkage. If no fault can be found there, the next step would be to remove the shifter cover and inspect the shifter mechanism where it operates the shifter drum. This doesn't usually cause problems, unless someone has messed with it before and screwed it up.
« Reply #31 on: April 03, 2016, 09:10:11 PM »
The external linkage? Are you referring to clutch cable?
Online scottly
« Reply #32 on: April 03, 2016, 09:12:54 PM »
No, the external part of the shifter. The clutch isn't suspect in any way.
« Reply #33 on: April 03, 2016, 09:19:26 PM »
Ok. What should I keep my eye out for?
Online scottly
« Reply #34 on: April 03, 2016, 09:28:01 PM »
Just take a picture of the external shifter for now. When and if you have to remove the shifter cover I can give you specific things to check.
« Reply #35 on: April 03, 2016, 11:45:11 PM »
Washer in clutch correctly mounted? It is convex, it grow outwards so it will work as a spring. Or if a washer is missing so the main shaft can move more than it should??
It was a thread about gear problem where the entire transmission was investigated. You might find something here.
http://forums.sohc4.net/index.php/topic,138663.0.html
« Reply #36 on: April 04, 2016, 03:39:12 AM »
Almost positive the washer is in there right, but now I am second guessing myself. Could this be a culprit to my issue? For future reference what's a good way to keep the clutch basket from spinning when installing the clutch basket nut?
« Reply #37 on: April 04, 2016, 04:12:53 AM »
Easier to do the clutch nut when engine is in the bike with drive chain to wheel. 5:th gear in and wheel to floor. I have used a piece of wood between case and front sprocket too.
Offline przjohn
« Reply #38 on: April 04, 2016, 05:27:38 AM »
Is the bike popping out of gear or is the clutch slipping, do you know the difference?
All this talk about the clutch seems like you are chasing butterflies if the bike is popping out of gear.
 Once power has been transmitted through the clutch it is effectively gone past that part of the system and the popping out of gear problem then would be past the clutch, meaning the transmission or the transmission operating system.
However, if the clutch is slipping than the power never makes it to the transmission. This usually appears under a load and is felt as a gradual feel in power loss and not a sudden stop in power like popping out of gear.
Since you state the bike is popping out of gear under no load it sounds like a transmission related issue and not a clutch issue.
« Reply #39 on: April 04, 2016, 05:45:14 AM »
It's definitely popping out of gear. It will pop out, then I have to put it back in to gear
Offline Kickstart
« Reply #40 on: April 04, 2016, 05:51:49 AM »
+1 to what przjohn is saying... unfortunately.
You most likely are going to have to crack the case and see what's going on in there.  But before you do that, I would take a close look under the shift cover.
Maybe the shift linkage arm is bent preventing the drum from shifting/turning all the way... long shot, but worth looking into before you crack the cases open.
- Chris
75' CB750F Blue (Project)
No Reserve Racing #171 AHRMA
    • http://forums.sohc4.net/index.php?PHPSESSID=76lh437jnn0cijrc81lvshmqg3&/topic,60973.0.html
« Reply #41 on: April 04, 2016, 05:57:11 AM »
thek that the small spring holds the roller arm dovn to the drum...if that is gone,,the drum vill turn free..and any load vill pressm it in free gear..im a 550 man ..but think you can get to the drum end,,just take the cover off.
.a easy fix..ve can hope
« Reply #42 on: April 04, 2016, 06:33:56 AM »
You guys are awesome,  thanks so much for all the input
« Reply #43 on: April 04, 2016, 06:36:21 AM »
Does the motor have to be removed to take the shift cover off?
« Reply #44 on: April 04, 2016, 06:56:07 AM »
Just to be clear and no missing clue: Earlier mentioned washer in clutch has nothing to do with slipping clutch, gear problems as the Flybox1 thread had. Quick and easy to check.
Then the gear mechanism that strynboen mention. This should keep the drum that control the forks which gears in place.
see another thread
http://forums.sohc4.net/index.php/topic,60626.msg658199.html#msg658199
Offline pmanning
« Reply #45 on: April 04, 2016, 07:03:10 AM »
I used to work with a guy that used his 750 for unsanctioned, privately organized, and highly illegal drag racing on weekends. (This was Birmingham, Al in the 1970s.)  He was quick but hard on his equipment.  He went through three or four transmission rebuilds in a year and probably less than 1,000 miles-bent shift forks, broken shift fork pins, rounded engagement dogs on gears, and wallowed out engagement slots on mating gears.  Since you don't know what kind of riding the bike was subjected to in those 13,000 miles it is hard to rule anything out.  You might pull the oil pan and see if there are shiny metal bits or chunks lying about there.
« Reply #46 on: April 04, 2016, 07:44:16 AM »
no, but there is oil behind it.
Check out Dino's documentation, it will help you understand how the shifter works:
http://hackaweek.com/hacks/?p=1649
In the worst case scenario, transmission can be dealt with from the bottom,  engine out of the frame and flipped over.  Done it myself to make the F3 engine shift to 3rd and higher.
« Reply #47 on: April 04, 2016, 08:10:41 AM »
I have never split a case, it sounds terrifying to me haha
« Reply #48 on: April 04, 2016, 08:51:05 AM »
Would anyone be interested in walking me through the process on a weekend for $100?
Offline MoMo
  • Ride like you're invisible
« Reply #49 on: April 04, 2016, 08:57:07 AM »
location???  and it does seem internal but check the linkage before pulling the motor...Larry
