Author Topic: Can't get the rear brake to work, cb 750 - 72  (Read 6045 times)
Offline persson-johan@hotmail.com
« on: April 05, 2016, 01:14:41 PM »
Hello!
Im in the middle of assembling my cb 750 - 72 ive been overhauling for two winters but im stuck with a weird problem with the rear brake.
The problem: When the rear wheel is mounted there's not enough adjustment to make the wheel brake. It barely brakes even with the nut fully tighten, and ive tried with different positions of the wheel - shortest wheelbase - longest wheelbase (shouldn't matter anyway). The brake pedal goes all the way down.
I never drove the bike or tested the brakes before tearing the bike apart so i don't know is it worked before. The brakes ar all cleaned and taken apart. The drum is well within spec. and so are the brakepads with about 4,5 mm left. The cam doesn't rotate to much that would indicate worn pads (see the pic) I have checked and triple checked everthing but i can't see the problem so im asking you guys for help!
Here are some pictures on the setup and i also took some measurements on the brake arm and brake stopper arm, maby i have parts from another year/model? Hope you guys can see something i can't :)
Brake arm (the one with adjuster nut) = 59 cm or about 23 1/8". End to pin hole centrum.
Brake stopper arm = 36.3 cm or about 14 1/8". c/c
Regards
Johan
Sweden
« Last Edit: April 05, 2016, 01:16:59 PM by Joper »
Offline Chachi
Re: Can't get the rear brake to work, cb 750 - 72
« Reply #1 on: April 05, 2016, 01:47:30 PM »
Do you have factory stamps on your brake actuator arm (top pic) so you know where to set it on the teeth/spindle? I have them on all my arms... rear brake, shifter, rear brake pedal.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Mitchell
« Reply #2 on: April 05, 2016, 01:50:11 PM »
Sounds like its either the arm on the brake drum or your brake pedal is in the wrong position maybe.
« Reply #3 on: April 05, 2016, 02:00:06 PM »
Yup, match up the dots stamped into the splined spindles and the mating arms and then there is  adjustment available one sline in either direction.  The dots can be hard to see.
« Reply #4 on: April 05, 2016, 11:41:33 PM »
I have the dot and they are lined up!
« Reply #5 on: April 06, 2016, 12:28:02 AM »
 Wrong length torque arm, perhaps ?
« Reply #6 on: April 06, 2016, 01:03:07 AM »
Might be the problem! Looks stock and hasn't been cut tho, but who knows. Anyone have the c/c length on that? Thats the one i call "brake stopper arm" with the measurements in the first post.
Offline MoMo
  • Ride like you're invisible
« Reply #7 on: April 06, 2016, 03:56:35 AM »
You can move the brake actuating arm from "normal" position rearwards one tooth that may give you the necessary leverage...Larry
« Reply #8 on: April 06, 2016, 06:11:26 AM »
I don't think that would be enough, i barely get any brake action when the pedal is all the way down. And it shouldn't be necessary with all the parts within spec.?
« Last Edit: April 06, 2016, 10:09:08 PM by Joper »
Offline MoMo
« Reply #9 on: April 06, 2016, 04:36:02 PM »
Could you post a close up of the brake actuating arm and pivot?
« Reply #10 on: April 06, 2016, 07:28:54 PM »
 Brake stopper arm appears to be right length, could be the rod...forgot to measure that.
You could run a spacer to take up some of the slack.
« Reply #11 on: April 06, 2016, 10:12:34 PM »
Thanks! Yes a spacer on the rod would probably solve it, but I'd like to find out what is wrong :)
I'll take some close up pictures on the pivot arm next time I'm in the garage.
Thanks for the help and answers!
« Last Edit: April 07, 2016, 07:40:53 AM by Joper »
« Reply #12 on: April 08, 2016, 03:28:53 AM »
Ok! Here are some pictures:
All the way back:
Here it starts to brake:
Adjuster all the way in...:
Pedal still waaay to far down and barely brakes:
Brake arm:
Notches lined up:
Here also:
Hard to get a good photo of this but here's a try:
I can't get my head around this..! Only explanation is a brake push arm that is too long. Anyone got any measurements on that? But yet i don't think the PO would have ridden around like this..
Thanks for the help!
« Reply #13 on: April 08, 2016, 06:38:06 AM »
My guess is you have the wrong part on there. What is the overall length of the rod?
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #14 on: April 08, 2016, 06:44:17 AM »
That's all it really could be, the rod is too long. Everything else seems to be in place where it should be.
--Evan
1975 CB750K "Rhonda"
Offline setdog
« Reply #15 on: April 08, 2016, 06:53:40 AM »
I just did mine the other day, I took the foot peg off and rotated the brake pedal arm back a few teeth, The marks on the brake pedal don't line up but I have nice feel and the fin on the actuator where the rod connects has no interference.  Then I put foot peg back on.
Took me several attempts to get it feeling right.  Seems a few times it looked good, felt good but was ridiculously squishy, so I had to keep fiddling.
« Last Edit: April 08, 2016, 06:57:46 AM by setdog »
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
Offline enwri
  • So that noise is normal?
« Reply #16 on: April 08, 2016, 07:24:17 AM »
77 CB750k,
Brake rod, 550mm to the saddle,
Brake stay 325 mm, centre to centre.
I have a shorter brake arm/lever 20mm shorter
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
Offline 2wheels
« Reply #17 on: April 08, 2016, 07:49:13 AM »
Just currious -
Do you have the chain on and adjusted?
What happens if you push the wheel forward as far as it will go?
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Offline MoMo
« Reply #18 on: April 08, 2016, 09:08:41 AM »
I would pivot the actuator arm back one notch . I've had to do that on several bikes
Offline theslayedsaint
« Reply #19 on: April 08, 2016, 09:49:44 AM »
+1 had to do the same thing with my bike.
1974 CB750 custom build cafe racer
-849cc big bore
-Webcam 63a
-APE rods
-4-1 stainless exhaust
-GSXR front end
« Reply #20 on: April 08, 2016, 10:00:41 AM »
Thanks for the replys! :)
I'll try and move the pivot arm one notch.
Did you measure up to the part that connects to the brake pedal? I had 590 mm from the end to the centrum of the hole where the brake pedal connects. I'll measure only the rod if that's what you did!
No chain on the bike and I have tried pushing the wheel to the end points, no difference.
I don't want to rotate the pedal while the peg is of. If you do that the angle of the arm get steeper and the leverage will be less.
Really appreciate the answers!
Offline enwri
« Reply #21 on: April 09, 2016, 06:45:29 PM »
Did you measure up to the part that connects to the brake pedal? I had 590 mm from the end to the centre of the hole where the brake pedal connects.
Just measured to the bottom of the saddle by sliding the tape up along the rod until it hit. It's dirty in there, swingarm grease overflow I've squished into the brake rod pivot saddle.
With new shoes, had to move it a notch in the other direction. Now they are worn in I put it back on the dots, drum or shoes worn, maybe a notch past.
Saw in the photos, the pedal stop adjuster bolt is threaded end down, if the end of the bolt gets mushroomed or bent it can be difficult to get out. My bolt is on the footpeg mount, so is different anyway. Don't know how yours should be, so, maybe just ignore that last line or two..
8? XJ 550 meh...
« Reply #22 on: April 10, 2016, 12:02:16 AM »
I got it to work with moving it one notch back, sweet! I still have to adjust it quite much but there's much adjustment left.
Well now it works!
Also I primed the oil pump yesterday, got the pressure up to 60 psi on the starter, fitted some plugs, hit the starter and it runs!! Hasn't been run since 94 I think :) just waiting for a chain and then it's time to bed the rings in!
Thanks for the answers. Really helped me out this time!
« Last Edit: April 10, 2016, 12:04:18 AM by Joper »
« Reply #23 on: April 10, 2016, 10:28:55 AM »
Good news! Got to ask how are you measuring the oil pressure, did you buy a gauge that goes go the oil galley?
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
« Reply #24 on: April 10, 2016, 12:32:43 PM »
I have a oil pressure gauge for cars and bikes that connects to the oil pressure light switch hole. I think I will have connected for the first run also. Later I won't have a gauge on the bike, only the stock oil light.
