Author Topic: Tensioner test - started 4/4/16  (Read 2209 times)
« on: April 06, 2016, 12:46:41 PM »
Moderators: I'm not sure if this is the best place for this post, move as may be required?
Some of us are getting the "recall notice" from CB750Supply about the suspected inferior cam chain tensioners. To test whether it is really the rubber (or not) at fault, I have started a test with a Honda tensioner and a Taiwanese tensioner, side-by-side, half immersed in used engine oil, in a clear container. (Pictures at 10 PM tonight) If the roller swells or shrinks (or something) on the half in the oil, it will be obvious after a while. The Honda part is right next to it (and has a stuck roller, came that way, so I never used it...) so the position will be consistent?
Here's one thought I have had about these tensioners, to mull over: all of the Tawianese ones I have seen (and a good number of the Honda versions, like the one in this test) have a sharp burr where the square bearing-retainer notch is punched in the tensioner's arm. If this burr is not removed at assembly, the arm will not pivot, or if it is forced to pivot, will tilt the oiling holes of the collar bearing toward the front of the engine. If this happens, the bearing inside will not receive much oil, as the oil splash for this system comes from the slack side of the cam chain (i.e. back side of the engine), by splash, collecting in the 2 horizontally-placed oil pickup holes. If the oil is lean or lacking (or too thin, like hot 10w40 weight, hint...), the bearing can score at engine speeds above 6000 RPM or so. Once scored, it eventually drags or even seizes. This for sure would tear up the larger lower roller. Something to think about?
« Last Edit: April 06, 2016, 05:51:51 PM by HondaMan »
Online CycleRanger
  • No comment about being an
Re: Tensioner test - started 4/4/16
« Reply #1 on: April 06, 2016, 09:22:41 PM »
You will need to apply heat to provide a more accurate simulation.
And I'd consider this a "product review".  :)
« Reply #2 on: April 06, 2016, 09:58:17 PM »
And friction, rotational forces and pressure at least  i'd imagine, it definitely doesn't stand still...
    • http://forums.sohc4.net/index.php?PHPSESSID=85d74llb65gbs9kh8g7vjvl055&/topic,60973.0.html
« Reply #3 on: April 07, 2016, 03:21:38 AM »
yes boil it a bit..then the kookie gets done farster :)
« Reply #4 on: April 07, 2016, 04:49:03 AM »
Following.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #5 on: April 07, 2016, 05:35:41 AM »
Interested in results.
--Evan
1975 CB750K "Rhonda"
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: April 07, 2016, 06:04:04 AM »
SCIENCE!
Well, more or less ;)
Following.
mystic_1
- John Augustus Shedd
Offline evanphi
  • Apparently I'm an
« Reply #7 on: April 07, 2016, 06:09:43 AM »
--Evan
« Reply #8 on: April 07, 2016, 07:08:20 AM »
Subscribed
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #9 on: April 07, 2016, 09:12:46 AM »
I was looking at those CB750Supply tensioners this morning.  I ordered an OEM instead.  Glad I did.
Bud
1973 CB750K3 Chopper (in pieces)
« Reply #10 on: April 07, 2016, 06:21:14 PM »
The test I am doing here (at least at first) is a simple "oil exposure' test, since that's what the recall purports to be the problem.
the problem with the bearing seizure can happen to any of these that are installed without making sure they pivot freely, and that would tear up even Honda's own part, so I'm kinda disregarding that failure mode with this test. These rollers typically don't run very long: a typical engine with, say, 50,000 miles on it, at an average of 50 MPH overall, has just experienced 1000 hours of run time, or if it were reduced to "oil exposure time', this would be about 42 days of "exposure". When the engine stops, the oil largely drips off, so this test will be somewhat more intense than just dunking it and then letting it sit out, where the oil would run off of it.
If nothing shows up after a month or two, I might consider putting it on heat of some sort to see if that changes anything?
What bugs me about all this is: I've got a lot of engines out there since 2012 (or whenever these showed up), when Honda was out of stock and these were used instead. Many times, the customer brings me his engine and parts, in those situations where they felt they could not finish the rebuild, and they have been these parts, too. I don't know of any troubles, at least yet? The slipper tensioner in those kits also seems to be fine, not chunking off any rubber that is showing up in the oil filters or crankcases.
Online CycleRanger
« Reply #11 on: April 07, 2016, 06:50:38 PM »
I'm betting it's oil+heat that's the biggest knob.
We need to to a DOE and ALT.  ;D
